Shameless update from Dale Kramer
Old March 20th 16, 06:52 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Default Shameless update from Dale Kramer
On Sunday, March 20, 2016 at 9:53:48 AM UTC-7, DaleKramer wrote:
I am not saying the mechanical dynamics behind the broomstick analogy is different, just the visualization of it is a little different.
You are correct - it was a crude analogy. The main point (which you clearly understand) is that whole thing in vertical flight is quite likely statically unstable and if it tips over beyond a certain angle of vertical it is likely to flop over nose down. Unless you have enough altitude when this happens to get flying speed and pull out...well it could be a problem. Ideally you want to keep it stable so you never get to that angle until you have flying speed, which entails tipping over with differential electric thrust enough to get flying speed through the deep stall where the wing and elevator can operate. Yes indeed adding big controls on the tail and big old Fowler flaps on the wing could help you get stable at a higher angle of attack and lower speed. Lots of the hybrid aircraft-helicopter designs I've seen resort to tilt-wing to facilitate the transition more easily but all of that adds weight and complexity.
A simple calculation would be (without benefit of the dimensions on your plans) 220 lbs of thrust from the bottom tail motors produces a nose-up moment of 880 lb-ft based on a 4-foot offset from the center of mass. If the center of mass is 5 feet in front of the lift of those two motors that are trying to hold the nose up and you have a TOW of say 500 lbs you'd end up with a nose-down moment of 2500 lb-ft which would overwhelm the ability of the lower motors to right the aircraft as you approach horizontal. Now calculating the nose-down moment for totally horizontal is not realistic as you'd be accelerating before you ever got to horizontal but a little trig would tell you roughly what kind of angle off vertical the voters have the juice to recover from. Obviously you also have the other motors pulling as well and the prop wash over the tail adds a bit of moment, but the motors on the vertical centerline mostly just reduce the effective mass feeding the nose-down moment for reasonably vertical orientations. They don't help you at all as you approach horizontal. I expect there is somewhere around 30-40 degrees off of vertical where things get interesting and you better have some forward velocity and altitude before you let the nose get that tipped over. Sounds like you have a computer program to figure it all out but my gut feel of is that the last half of the transition to forward flight could get pretty sporty - wing still stalled but the two bottom motors have run out of ability to add enough nose up moment. The reverse maneuver could be even more exciting - a zoom has been mentioned.
Of course with enough thrust almost anything is possible. :-)
Again, thanks for sharing. Interesting design. All in all I think I'd rather have one of these than those scaled-up quadcopter drones people are promoting for personal transportation. Yikes!
Andy
Art Kramer Andrew Chaplin Military Aviation 8 July 12th 04 11:25 PM
Art Kramer, your computer may be infected old hoodoo Military Aviation 6 May 24th 04 12:43 PM
Question for Art Kramer. M. H. Greaves Military Aviation 2 May 10th 04 05:17 PM
More B-26 Nonsense from Art Kramer funkraum Military Aviation 7 January 21st 04 10:53 PM
ATTN: Art Kramer robert arndt Military Aviation 2 July 4th 03 02:33 PM
