Do L'Hotellier Ball Fittings Wear?
Old April 13th 16, 12:04 PM posted to rec.aviation.soaring
Casey[_2_]
Default Do L'Hotellier Ball Fittings Wear?
Just wondering if L'Hotellier fittings wear? I can't seem to find what the tolerance is for the ball diameter. Just curious.
I am aware of the min travel of the locking plate of 2mm.
Thanks
Casey
Old April 13th 16, 12:33 PM posted to rec.aviation.soaring
James Thomson[_2_]
Thanks
Casey
L'Hotellier don't specify a limit on the diameter itself, they specify a
limit on out-of-round. Their directions a
"The variation between several measures of the ball diameter must not
exceed 0.1 mm.
This check aim is to detect abnormal ball wear"
You should be able to download L'Hotellier's instructions from the
internet - they usually form part of the ADs issued on this equipment!
Jim Thomson
Old April 13th 16, 12:46 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Yes, they wear. Ask the driver of the Nimbus 4 M in Washington that crashed on takeoff due to a worn l'hotellier Coming off the ball due to wear.
Old April 13th 16, 01:46 PM posted to rec.aviation.soaring
krasw
They do not wear if kept clean and lubricated. My fittings have exactly same dimensions as 1000 hrs ago. Bare metal against metal with some dirt between and yes, they most likely wear.
Old April 13th 16, 01:51 PM posted to rec.aviation.soaring
Tango Eight
Guess embarrassment overcame concern for other aviators then... no NTSB report found. I want to know how it was proven that a properly assembled, safetied & pre-flight inspected l'hotellier failed as you say. I'd also like to know if some astounding number of flight hours was involved and if anything unusual pertained to the service history (e.g. stored in Pacific Surf, lubricated with silicon carbide lapping compound, 3000 & 6000 hr life extensions pencil whipped by village idiot, you know, all the usual stuff).
Serious question btw.
Evan Ludeman / T8
Old April 13th 16, 02:06 PM posted to rec.aviation.soaring
Casey[_2_]
Thanks for the comments.
I'm wonder what the dimensions of the balls are new.
My aileron balls on both wings are 0.02 mm smaller than the spoiler balls on both wings. Dimensions are same on each wing.
What is best lubricant? Thicker grease or thiner spray? I know the pro and cons of each but just wonder others thoughts.
Casey
Old April 13th 16, 02:52 PM posted to rec.aviation.soaring
Tango Eight
Evan Ludeman / T8
Okay, with a little PM assistance from Jonathon (thanks Jonathon) I was able to find the NTSB report. I had searched on manufacturer plus Washington state and the NTSB has the manufacturer misspelled in this accident report.
As far as the NTSB is concerned, it's failure to properly assemble and preflight, so admitted by the pilot.
best,
Evan Ludeman / T8
Old April 13th 16, 03:37 PM posted to rec.aviation.soaring
Tango Eight
lol, I'm the idiot in a hurry with a worn out keyboard. *I* got it wrong in my initial search, but still got results and didn't catch my mistake.
oops.
I'm more careful at assembly time (good thing, eh?).
best,
Evan / T8
Old April 13th 16, 03:48 PM posted to rec.aviation.soaring
Casey[_2_]
L'Hotellier web site has little info. An email to them and I was sent the maintenance Instruction.
https://www.dropbox.com/s/ii53drru82...01-00.pdf?dl=0
Casey
Old April 13th 16, 03:52 PM posted to rec.aviation.soaring
Casey[_2_]
And it appears if the protrusion of locking lever is less than 2mm indicates the balls need replacing and I think I would replace the connectors as well.
Casey
Source of L'Hotellier Fittings? Six-Seven Romeo Soaring 2 September 1st 15 05:33 PM
Brass Compression Fittings,Fittings for Pex-Al-Pex Sale on good price valvetom Piloting 0 November 27th 06 05:58 PM
L'Hotellier [email protected] Soaring 5 September 9th 05 04:21 PM
wanted L'Hotellier ball fitting assembly Udo Rumpf Soaring 3 January 7th 05 03:05 AM
Hotellier connections Mike Soaring 38 September 28th 04 04:30 PM
