AOA indicator
Old April 30th 16, 03:43 PM posted to rec.aviation.soaring
Default AOA indicator
The most important thing is not either of those two instruments, its your ass, and situational awareness. Most folks get into stall/spin trouble by not having a clue that they are flying on or approaching the edge. An instrument only helps when theres time to scan it, but your ass can tell you immediately whats going on.
Dan
Old April 30th 16, 06:39 PM posted to rec.aviation.soaring
On Saturday, April 30, 2016 at 9:07:40 AM UTC-5, kirk.stant wrote:
On Friday, April 29, 2016 at 6:18:00 PM UTC-5, 2G wrote:
The MOST important thing to do is to maintain coordinated flight. Maybe you could put an audible warning on the yaw string!
Tom
I don't agree. The MOST important thing is to not exceed stalling AOA. Below that, yaw (within limits) adds drag (or may help a bit - see discussions about slipping turns while thermalling) and may be less efficient; but you can still control your glider - exceed the critical AOA, and you are a passenger until you reduce it.
Airspeed indicators are required (which are indirect AOA indicators). Yaw strings or slip balls are not.
Kirk
66
I think you got it right, Kirk. Not all of us can be fighter pilots but we all can learn about AOA and how critically important it is in most flight regimes. Every couple of years I read my "Stick and Rudder" by Langewiesche.. He was a very smart man and put things together 70 years ago that are still a mystery to many of us.
Old May 2nd 16, 01:36 AM posted to rec.aviation.soaring
2G
Tom
Kirk
66
Well, I definitely take issue with "ASI are indirect AOA indicators". This falls into the category of "it either is or it isn't" category.
I am not dismissing AOA indicators since I have never flown with one. I think I will put one on for my next flight (a yaw string taped to the side of the canopy).
You are very dismissive of the roll of gusts: a former FAA administrator was killed by one (and his inability to deal with it). You also did not comment on my comment about not being able to stall a glider above a 30 degree bank angle. Recovering from a straight-ahead stall is a ho-hum event at best; dealing with stall-spins is a totally different animal.
Tom
Need VOR indicator blanche cohen Owning 5 July 23rd 07 04:37 AM
Need VOR indicator blanche cohen Instrument Flight Rules 5 July 23rd 07 04:37 AM
Which Indicator for KLN-89b N7936T Instrument Flight Rules 3 June 1st 06 06:50 PM
WTB: ARC 300 ADF Indicator Ben Smith Aviation Marketplace 0 August 30th 04 09:19 PM
Non TSO'd IFR indicator Paul Lee Home Built 1 September 19th 03 07:00 PM
