LS3a vs Pegasus
Old April 28th 16, 01:21 PM posted to rec.aviation.soaring
gkemp
Default LS3a vs Pegasus
On Wednesday, April 27, 2016 at 8:18:32 PM UTC-7, IA DPE wrote:
I really wanted a Pegase, but I weigh 225 lbs, and best as I can tell by the POH, max pilot weight of a 101 is 185. This is max weight of non lifting surfaces minus empty weight.
If someone can show me different I'll certainly listen!
Never weighed under 245, put in a tail tank and flew it for years including my 1000K
gary kemp
Old April 28th 16, 01:36 PM posted to rec.aviation.soaring
Eric Munk
This varies per aircraft. Depends on the actual empty weight of non-lifting
components (fuselage, stabilizer), and therefore damage history and
equipment fitted. I have two in maintenance with a 225+ lbs max weight (227
and 231). 242 (and a bit) is maximum load per design specifications
(seatbelts and attachment) if max non-lifting is not reached before that.
Old April 26th 16, 09:46 PM posted to rec.aviation.soaring
On Tuesday, April 26, 2016 at 8:31:28 AM UTC-7, wrote:
Well, what do you think? I'm in the market and both are available with the LS having a higher asking price by a couple of thousand. Assuming similar trailers and instruments, is there a significant performance difference? Most Peg owners seem to love them and there is the DG/LS "tax" to consider. From what I've been able to gather, the Pegasus "hard to get parts" issue is mostly a myth. I have no time in flapped ships but not against them by any means. I'm currently flying an ASW 15.
- Not sure where do you fly, but Ls-3a in Midwestern, less than desirable, conditions would always beat the me in a thermal - I flew asw-19, which apart from a French designed airfoil isn't too far off from the Pegasus. I always envied the other pilot flying Ls-3 turning in thermals I kept falling out of. It was no competition between the two of us flying, same with run, simple gear change in the Ls-3 left me behind and lower. It convinced me I wanted a flapped ship.
The only down side was the weight of the wing on Ls-3. When he was pulling fuselage out of the trailer, entire gaggles used to scramble, leaving behind only children, elder and unenlightened...
Old April 26th 16, 09:51 PM posted to rec.aviation.soaring
Let me know if your going to sell your 15, I would be interested in it if you put her up for sale.
Dan
Old April 30th 16, 01:37 PM posted to rec.aviation.soaring
Dan
I noticed your interest in an ASW-15B. Mine is for sale and is posted on Wings & Wheels. Jack
Wanted: LS3A or LS3A-17 (USA) Uniform Zulu Soaring 1 November 21st 07 07:36 PM
LS3A performance Rob Dunning Soaring 7 July 7th 07 03:38 PM
FS - LS3a Simon Waddell Soaring 0 January 17th 04 04:05 PM
OPINIONS ON AN LS3A Gordon Schubert Soaring 6 November 14th 03 10:41 AM
Drag of LS3 compared LS3a. Peter Warburton Soaring 0 August 18th 03 06:59 AM
