My "non engineering" comment is..... A similar airfoil was used on the PIK-20, SGS-135 and others.
When clean, it worked well. When dirty (bugs, dust, rain) the bottom dropped out. Common cure was: -sand to 45* of chord with 600 grit -wipe D-tube with liquid dish soap and let dry Sanding allowed a turbulent boundary layer, soap sheeted water, thus killing drag! Long final glide in a "20" with others into Mifflin, a 1-35 (highly modified) showed the drag gain when we hit rain showers, he had a tough time, we made slight adjustments to final glide. So, that airfoil can be good clean,but really sucks when dirty. No, you DON'T want a high gloss finish!!! |
![]() Quote:
FWIW I used to have a share in a Janus and I too found that having some extra positive of flap and flying a little slower helped to avoid the plummeting when wet. No hard figures to verify that but the airframe shaking went away as well so more comfortable for the poor old pilot. :-) Colin |
On Tuesday, July 12, 2016 at 2:45:32 AM UTC-4, Tango Whisky wrote:
The method by Dick Johnson works for gliders with limited performance. Even in "still air conditions", which are typically found in meterological high pressure regions, there are wide-area vertical movements of air. There is no way that the method by DJ can work them out... In addition to airmass movement, there are a couple other serious problems with the methods used: 1) The CG of the plane was not controlled. - what is the effect of forward vs. aft CG on max LD? - what popular plane was measured with a very low LD due to above? Discuss amongst yourselves... 2) The number of (and selection of) datapoints is not adequate Discuss amongst yourselves... ...That's why in Europe, DJ measurements are widely disregarded. Yup. |
On Thursday, July 14, 2016 at 9:00:22 AM UTC-5, Dave Nadler wrote:
On Tuesday, July 12, 2016 at 2:45:32 AM UTC-4, Tango Whisky wrote: The method by Dick Johnson works for gliders with limited performance. Even in "still air conditions", which are typically found in meterological high pressure regions, there are wide-area vertical movements of air. There is no way that the method by DJ can work them out... In addition to airmass movement, there are a couple other serious problems with the methods used: 1) The CG of the plane was not controlled. - what is the effect of forward vs. aft CG on max LD? - what popular plane was measured with a very low LD due to above? Discuss amongst yourselves... 2) The number of (and selection of) datapoints is not adequate Discuss amongst yourselves... ...That's why in Europe, DJ measurements are widely disregarded. Yup. For reference see Paul Bikle's "Polars of Eight" in Soaring magazine. |
Dave Nadler said
1) The CG of the plane was not controlled. - what is the effect of forward vs. aft CG on max LD? - what popular plane was measured with a very low LD due to above? Discuss amongst yourselves... So what is the typical percentage change in L/D from full forward CG to maximum rearward CG? Is it a huge change (10%) or minor change? I have no idea. |
Dick Johnson | Clint | Soaring | 4 | June 6th 09 10:40 PM |
Texas Glider Rally / Dick Johnson Wave Camp April 4 - 11 at Marfa | Burt Compton - Marfa | Soaring | 2 | March 27th 09 06:55 PM |
Dick Johnson is gone. | Burt Compton - Marfa | Soaring | 23 | July 27th 08 05:38 PM |
Dick Johnson's FTE of the Discus-2 | Flavio Formosa | Soaring | 1 | January 18th 07 03:18 PM |
Contacts of Dick Johnson | Francisco De Almeida | Soaring | 1 | January 1st 06 06:07 PM |
