On Wednesday, August 3, 2016 at 7:13:28 AM UTC-7, wrote:
"Seems to me that if you are in danger of spinning from a shallow turn in the landing pattern, you are going much too slow." Exactly. Or, if you are going much too slow you are in danger from spinning from a shallow turn in the landing pattern. If you are going much too slow you are in less danger from spinning from a medium/steeper turn in the landing pattern because at low speed most gliders run out of up elevator authority before reaching critical angle of attack. If so, you have another problem -- the steep turn likely puts you below the speed at which the wings are creating enough lift to keep you in the air. At altitude, the nose will fall and you will pick up speed. Close to the ground, you may impact the terrain. |
Exactly. Or, if you are going much too slow you are in danger from spinning from a shallow turn in the landing pattern. If you are going much too slow you are in less danger from spinning from a medium/steeper turn in the landing pattern because at low speed most gliders run out of up elevator authority before reaching critical angle of attack. |
Not commenting on whether this is true or not but only to inform of at least one place where glider pilots are taught that steeper turns are less likely to result in a stall. From Glider Basics - From First Flight to Solo, by Tom Knauff:
"It is very important for you to understand it is extremely difficult, if not impossible, to stall a glider in turns of 30 degrees angle of bank or more." You can find the entire discussion on page 79 of his book, as well as in multiple other locations in the text. Robert On Tuesday, August 2, 2016 at 3:22:20 PM UTC-5, Tango Whisky wrote: Le mardi 2 août 2016 22:07:26 UTC+2, a écritÂ*: At higher G loading as in steep turns many if not most gliders run out of elevator authority making them difficult if not nearly impossible to stall. Airplanes on the other hand have the propeller wash influencing elevator authority. If your talking bank angles beyond 60 degrees, maybe. Anything below - absolutely not. That is, if you respect max mass in the seat. Actually, if you stall a 25+ m ship at 60 deg bank, spin entry is much more violent than at 30 deg bank, and stopping the spin takes significantly more time. I've done that, and I won't do it again. So, relating to patterns where you probably don't do more than 45 degree banks, your statement is senseless. |
Downwind to final turns | Jonathan St. Cloud | Soaring | 18 | June 7th 15 02:19 PM |
Base to Final - Fatal | Orval Fairbairn[_2_] | Piloting | 0 | August 8th 10 03:23 AM |
The Art of Racing - Final Turn.jpg (1/1) | Mitchell Holman[_4_] | Aviation Photos | 0 | February 27th 10 12:42 PM |
Final Approach, pt 3 - KFME final.jpg (1/1) | Mitchell Holman[_3_] | Aviation Photos | 0 | April 8th 09 12:56 PM |
Turn to Final - Keeping Ball Centered | skym | Piloting | 224 | March 17th 08 03:46 AM |
