Good sailplanes for tall pilots?
Old September 12th 16, 03:04 PM posted to rec.aviation.soaring
Default Good sailplanes for tall pilots?
You should consider the LS4/6/8.
Large pilots usually completely remove the adjustable seat back. The rear cockpit bulkhead is flat and sloped just like a seatback. The LS series is designed to fly with a parachute.
Old September 12th 16, 03:54 PM posted to rec.aviation.soaring
Dan Daly[_2_]
In the lower price range, the Standard Jantar usually has PU paint and has a very lengthy cockpit - second biggest cockpit (after the Genesis) I've seen. Long arms would be a bonus - instrument pod is well forward. Usually one on Wings and Wheels.
The HpH304 Shark is also very big, but way out of your stated price range.
Ka6 - I'm 5'10" and found the Ka-6e to be snug for my height - had a 1/3 share for a year. 1-26's were bigger inside (though not particularly comfortable after an hour or two).
Old September 12th 16, 07:45 PM posted to rec.aviation.soaring
A Genesis 2 would be a good choice. Single seater though.holds a 155-242 lb. Pilot and is very roomy..
Old September 13th 16, 06:23 AM posted to rec.aviation.soaring
SoaringXCellence
A few of you mentioned the Lark; I thought they were all getting scrapped because of the life limit issue. Has anything improved on that front? A Lark might be a cheap thing to get and make available to the club.
Not all Larks are subject to the life limit: there's on on W&W that is not and I flew it on Saturday, I kind of wish the club wasn't selling it!
MB
Old September 14th 16, 06:32 PM posted to rec.aviation.soaring
Marcin S
On Wednesday, September 7, 2016 at 7:19:05 PM UTC-4, wrote:
I am 6'4" tall. I weigh about 200-210lbs clothed. My height is fairly evenly distributed between legs and torso. My arms are rather long, though.
Please help me start developing a shopping list for a decent glider that I can enjoy owning and flying without cramps or impeded control movements. This would be my first foray into ownership, but I expect to own multiple in the future.
Factors to consider:
1. Prefer 2-place to single-seat, but I'm open to both.
2. If 2-place, must be FAA type-certified with standard airworthiness certificate. No experimentals. I want to be able to give commercial rides, instruction, and CAP cadet o-rides. Solo ships can be experimental, but not amateur-built.
3. Will consider self-launchers, sustainers, and motorgliders, but not looking to get into that price range.
4. Will consider antiques & open cockpits, if they have a provenance.
5. Not concerned with competition.
6. Acro would be a plus.
7. Will consider something life-limited (e.g., Lark) if I can get it super-cheap to use as a disposable platform for a couple hundred hours to better identify what I really want from a glider.
8. Priced under $30k, $10-15k is better.
My experience:
Highly active airplane pilot, IFR, 1000+ hours. Low-time glider pilot (100 hrs).
Here's what I have flown:
L-23: Fits okay, not very charming to own.
ASK-21: Tight, but doable
G103: Tighter than the ASK-21, prefer to avoid
Bergfalke: Antique wooden open-cockpit novelty; not a candidate.
I'll be trying out a SGS 1-23 and an LS-1f this weekend. There are several KA-6 models for sale all over right now (did they just get hit with an AD or something?), so some targeted opinions on these 3 would be timely.
Cheers
Hi,
I have a Jantar Std 2 that has a very long cockpit. It has 6 adjustment points for the seat back and I fly on number 4 and I am 6 ft and weigh 215 lbs. I am sure you can easily fit.
The glider is available for sale and you can see some pictures he https://goo.gl/photos/UEKBzcrxa9PZNGQs7
Here is a link to my olc flights: http://www.onlinecontest.org/olc-2.0...t=olc&pi=56048
and a video of a flight a while ago: https://youtu.be/MPw29q5XuKE
Thanks,
Marcin
Old December 2nd 16, 03:09 AM posted to rec.aviation.soaring
My experience:
Cheers
I'm a lanky 6'4" and fit with an old thick parachute nicely into a Glasflugel Mosquito...
Old December 2nd 16, 10:51 PM posted to rec.aviation.soaring
My experience:
Cheers
Hello! We have two gentlemen on our club, one 6'6" (Bill)and one 6'7" (Chip). Bill is an ex-air force pilot who had a similar story. He gives rides in ONLY our G103, but bought an LS4, because it was the ONLY aircraft he felt most comfortable in. He removes the back seat pan, and wears a parachute, laying against the bulk head, but has had numerous 4+ hr flights. He is also a tow-pilot. Chip will ONLY fly our G103. I hope this helps?
-eagleyez
Old December 2nd 16, 11:03 PM posted to rec.aviation.soaring
My experience:
Cheers
We have two guys in our club, one is 6'6" (Bill) and the other 6'7" (Chip). Both guys will ONLY give rides in our G103. Bill is an Ex Air Force Col., who had a similar problem as you. He found an LS4 that was the "most" comfortable for him. He took the Seat Back out and flies with a parachute against the bulkhead and has had numerous 4+ hr flights. You also might consider an LS3a without a seat back, if you would like flaps? I hope this helps? Happy Searching!
-eagleyez
Sooo ... Glider pilots DO make good jet pilots! AS Soaring 2 November 30th 15 09:02 AM
Good news for pilots - retirement age Greg Farris Piloting 48 January 29th 07 01:57 AM
About Good Pilots and Bad Pilots Dudley Henriques Piloting 96 February 23rd 06 01:19 AM
Are pilots really good or just lucky??? Icebound Instrument Flight Rules 68 December 9th 04 01:53 PM
Tall pilots in Helo's... BEEPER708 Rotorcraft 5 September 5th 03 05:05 AM
