Libelle spoilers
Old September 10th 16, 07:22 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Libelle spoilers
On Sat, 10 Sep 2016 06:54:50 -0700, johnsinclair210 wrote:
There is a gear box on the root rib that changes rotational input to
push-pull output that drive the spoilers. I remember one bird that I was
unable to free up this gear box. The gears are inside a fiberglass
box..........the only way I could see to get some lube in there was to
drill a 2mm hole in the fiberglass box. Worked like a charm.
JJ
Thanks, JJ. I knew there had to be a rotary-to-linear converter somewhere
in the wing and I had wondered where it is and how it worked.
Using an oilcan to put a bit of oil on the end of the bearing where the
shaft enters the root rib worked last time in the workshop so I'll try
the same trick again.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 29th 17, 06:00 PM posted to rec.aviation.soaring
Hi JJ, you may just be able to save my life! I also have a standard Libelle with only 650 hours on it. But the airbrakes are really stiff and it is clear it is the gearbox in the wing roots. I have tried to get lubrication in there and failed and want to drill the 2mm holes. But, where exactly do I drill them and what lubricant would you recommend please
Old September 10th 16, 11:47 PM posted to rec.aviation.soaring
Gav Goudie[_2_]
Or one or more DU bushes are worn inside the wings.
Ask Streifender for advice, replacing them isn't too big a deal.
http://www.streifly.de/home-e.htm
GG
At 00:35 10 September 2016, JS wrote:
Thanks, JJ. So lubrication is the secret!
Something like LPS1 perhaps?
http://www.lpslabs.com/product-details/560
Unsure if it's available in Britain.
Old September 13th 16, 10:05 PM posted to rec.aviation.soaring
DU?
Will do. Thanks.
org |
Old September 12th 16, 12:45 AM posted to rec.aviation.soaring
Are the airbrakes stiff over their whole range? Or is it just the over-centre that's difficult to overcome?
Nick.
Spoilers, no spoilers? Amine Piloting 39 February 14th 08 02:37 AM
Flaps/spoilers on which sailplanes? [email protected] Soaring 11 December 31st 06 01:12 AM
spoilers vs. ailerons [email protected] Piloting 36 August 8th 05 11:24 AM
Frozen spoilers stephanevdv Soaring 0 November 4th 04 05:24 PM
L-13 Spoilers Scott Soaring 2 August 27th 03 06:08 AM
