Birds in the hangar
Old November 5th 16, 12:48 PM posted to rec.aviation.soaring
Jim Kellett
Default Birds in the hangar
On Friday, November 4, 2016 at 9:36:19 AM UTC-4, Dave Nadler wrote:
On Friday, November 4, 2016 at 6:38:35 AM UTC-4, AS wrote:
The birds (pigeons) in our hangar died suddenly from high velocity lead poisoning.
Oddly, the roof started leaking just afterwards...
Using wrong ammo. I used .22 scattershot to rid a hangar of pigeons quite effectively some years back.
Old November 4th 16, 01:12 PM posted to rec.aviation.soaring
On Thursday, November 3, 2016 at 5:43:22 PM UTC-8, Ben Coleman wrote:
Our club is discussing what we can do to deter birds from perching in our hangar and messing up our aircraft. Can anyone recommend a technique? Are there any methods which have not worked?
The birds are small, probably swallows.
Thanks Ben
You might try keeping a light on in the hangar.
I put a LED floog light in the hangar and left it on 27/7 and the birds have not returned.
bob
Old November 4th 16, 01:26 PM posted to rec.aviation.soaring
glidergreg
Thanks Ben
We have used the Bird X QuadBlaster QB-4 for over a decade, works very well keeping birds out of the hanger, Emits a very high pitch series of sound pulses that most people can not hear, some younger people can detect it and find it annoying. This devise is not cheap around $550.00. we have it mounted on a side wall of a 60 x 60 hanger. Installed a on off wall switch to shut it down when necessary. Web site URL http://www.bird-x.com/quadblaster-qb...hp?page_id=103
Old November 4th 16, 08:27 PM posted to rec.aviation.soaring
Ben Coleman
Good to hear these gizmos work, this is one of the proposals for our club (using a mix of ultrasonic and audible sounds including distress and predator sounds).
Regards Ben
Old November 5th 16, 04:12 AM posted to rec.aviation.soaring
JS
Regards Ben
The electronic noisemakers were thought of as "most people cannot hear" or "all you hear is an intermittent clicking noise".
It's not as bad as the Ludovico treatment*, but probably best to turn the thing off when people are around unless they're deaf in one ear and can't hear out the other.
* from "A Clockwork Orange"
Old November 4th 16, 04:20 PM posted to rec.aviation.soaring
lynn
Thanks Ben
I installed bird netting to the underside of the rafters effectively taking away the perching areas. Birds disappeared from the hangar.
Old November 6th 16, 08:32 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Anyone that thinks shooting any type of projectile in a hanger is a good idea, clearly has not thought that through and through, so to speak. Projectiles ricochet, miss targets, poke holes or put dents in things you would rather not.
I have used the electronic counter measures with only limited success. The Plastic Owls did not help at all.
On Sunday, November 6, 2016 at 11:43:07 AM UTC-8, gotovkotzepkoi wrote:
A 20 gauge shotgun would work quite nicely.
gotovkotzepkoi
Two Birds Avsec Aviation Photos 2 January 29th 08 01:19 PM
Birds, Birds, Birds! Kyle Boatright Piloting 4 October 30th 07 04:04 PM
Are birds IFR? Kevin Clarke Instrument Flight Rules 28 September 30th 06 08:57 PM
The BIRDS Kyle Boatright Piloting 29 March 5th 06 11:50 AM
Fat Birds Bob Chilcoat Piloting 14 January 29th 06 01:27 PM
