Are 'Single 180 Turn From Downwind to Final' and 'Stall-spin on Turnfrom Base to Final' mutually exclusive?
Old November 20th 16, 10:03 AM posted to rec.aviation.soaring
Bruce Hoult
Default Are 'Single 180 Turn From Downwind to Final' and 'Stall-spin onTurn from Base to Final' mutually exclusive?
On Sunday, November 20, 2016 at 2:24:53 AM UTC+3, 2G wrote:
On Saturday, November 19, 2016 at 9:52:04 AM UTC-8, Dan Marotta wrote:
My Stemme has built-in AoA indication but it's on the EFIS and I'm
looking outside during the pattern. All you really need is to be able
to recognize sloppy controls, reduced noise, and uncommanded movement of
the nose. This has been discussed to death (no pun intended). There's
no instrument that can protect you as well as training and practice and,
if you need to rely on an instrument, maybe you should be keeping
tropical fish instead of flying.
On 11/18/2016 11:29 PM, 2G wrote:
On Friday, November 18, 2016 at 8:06:21 AM UTC-8, Dan Marotta wrote:
To reply to the subject question in a word: NO.
You can stall and spin from any attitude or airspeed. All you have to
do is plan and execute it correctly or simply f*ck up the turn.
On 11/18/2016 6:25 AM, wrote:
An AOPA article states that the AOPA Safety Institute and University of North Dakota are studying the "circular vs rectangular" pattern as a result of the NTSB "Most Wanted Safety Improvements. It'll be interesting to see what the study produces.
Dan, 5J
It's REALLY hard to spin while flying coordinated - if you know of a way I would truly like to know. It is also tough to stall while flying coordinated because it takes a very high angle of attack and you would really have to work it keeping the glider coordinated as you approach stall. The FAA is emphasizing an angle of attack indicator to prevent spins; I think what is needed is an audible flight coordination indicator. In our gliders we have a heads-up flight coordination indicator which is even better - it's called a yaw string (but you have to look at it and react to it).
Tom
Dan, 5J
I rely on my instruments EVERY time I fly, especially in the landing phase; don't you? Training and practice are a good thing, but they CAN'T substitute for good instruments, only teach us to use them properly. One can compensate for the loss of an instrument, like airspeed, but one would not deliberately not pay attention to a working ASI in the landing phase.
The airspeed is the only instrument I pay attention to, and only really to see if it unexpectedly changes. Otherwise it's all by angles and feel. Audio vario is nice to have, but you know via your bottom and the changing view.. Precisely controlling the actual airspeed value is only really useful landing into a much smaller than usual field. I normally touch down at low energy within 20 ft of where I mean to.
I, too, have an AOA; it is the artificial horizon in my Air Avionics (aka Butterfly) vario.
Since when is an artificial horizon an AOA indicator? What's it telling you when you pull too hard nose 45+ degrees down on a loop exit or spin recovery?
Old November 19th 16, 11:29 PM posted to rec.aviation.soaring
kirk.stant
Link to the AOPA/UND landing pattern safety study:
https://www.aopa.org/news-and-media/...lized-approach
No doubt in my mind which is the safer way to fly a pattern - the one that doesn't require rolling into and out of several 90 turns at low altitude...
I hope they also evaluate the best way to enter a pattern - The beauty of using the overhead entry to downwind (See AIM for details) is that if you know the field elevation, an overhead pattern will always put you at the same place on downwind relative to your landing aim point, regardless of whether it's your home airfield or someplace you have never been before. Combined with a 180 turn to land, it makes arrivals and landings reliably repeatable and consistent - and safer, IMO (and apparently in the opinions of most militaries, etc...).
Looking at this image of experienced pilots landing (cribbed from a previous post, thanks!) http://noss.ws/temp/patterns.jpg, I see only ONE trace that is a classic square pattern, with a couple more that are a bit less angular. The rest seem to be more or less continual turns to final.
Kirk
66
Downwind to final turns Jonathan St. Cloud Soaring 18 June 7th 15 02:19 PM
Base to Final - Fatal Orval Fairbairn[_2_] Piloting 0 August 8th 10 03:23 AM
The Art of Racing - Final Turn.jpg (1/1) Mitchell Holman[_4_] Aviation Photos 0 February 27th 10 12:42 PM
Final Approach, pt 3 - KFME final.jpg (1/1) Mitchell Holman[_3_] Aviation Photos 0 April 8th 09 12:56 PM
Turn to Final - Keeping Ball Centered skym Piloting 224 March 17th 08 03:46 AM
