I did grasp that, but you might play around a bit more and learn things which will make general statements like yours look, well, not quite intelligent.
No reason for me to continue this discussion. |
On 11/23/2016 11:11 AM, Tango Whisky wrote:
I did grasp that, but you might play around a bit more and learn things which will make general statements like yours look, well, not quite intelligent. Well-intended advice noted, thanks. For the record (and no sarcasm intended), I stopped worrying about that aspect of "general statements" upon encountering the contention, "All generalizations are false, including this one." Everyone encountering a generality is free to individually decide if there is - or isn't - some kernel of "reality-based wisdom" in it. No reason for me to continue this discussion. Bob W. |
Bob Whelan wrote on 11/22/2016 9:06 PM:
True, before the wing "let go" there was (almost always) an absence of aerodynamic burble felt through the stick or one's butt or merely "drummed" through the metal fuselage, but by the time the wing did let go, "all the other usual suspects" had put in their appearances: low wind noise; nose noticeably high; controls (especially stick) getting sloppy; etc. Subsequent to checking out in the ship, I found it "intellectual fun" to mess around with it in slow flight "trying to find the burble." Abrupt departure from controlled flight - yes, indeed! "No warning?" - not by a long shot. The nose was not noticeably high in either glider (20 C or 26E); the wind noise was subdued, but both gliders were very quiet, and the change in noise was very small; there was no burble or "butt feel"; the controls were light but not unusually so; and the wing "departure" was not abrupt - I simply ran out aileron, and the wing would start downward. I'm guessing the inside wing tip doesn't stall, but can't be sure about that. But that scenario is with a shallow turn - 20 degree bank? - and at 30-40 degrees bank, it was harder to provoke the incipient spin. Much harder, as I recall. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
On Saturday, November 26, 2016 at 6:50:46 AM UTC+3, Eric Greenwell wrote:
Bob Whelan wrote on 11/22/2016 9:06 PM: True, before the wing "let go" there was (almost always) an absence of aerodynamic burble felt through the stick or one's butt or merely "drummed" through the metal fuselage, but by the time the wing did let go, "all the other usual suspects" had put in their appearances: low wind noise; nose noticeably high; controls (especially stick) getting sloppy; etc. Subsequent to checking out in the ship, I found it "intellectual fun" to mess around with it in slow flight "trying to find the burble." Abrupt departure from controlled flight - yes, indeed! "No warning?" - not by a long shot. The nose was not noticeably high in either glider (20 C or 26E); the wind noise was subdued, but both gliders were very quiet, and the change in noise was very small; there was no burble or "butt feel"; the controls were light but not unusually so; and the wing "departure" was not abrupt - I simply ran out aileron, and the wing would start downward. I'm guessing the inside wing tip doesn't stall, but can't be sure about that. Stick quickly a little bit forward restored aileron authority? |
Bruce Hoult wrote on 11/26/2016 12:40 AM:
On Saturday, November 26, 2016 at 6:50:46 AM UTC+3, Eric Greenwell wrote: Bob Whelan wrote on 11/22/2016 9:06 PM: True, before the wing "let go" there was (almost always) an absence of aerodynamic burble felt through the stick or one's butt or merely "drummed" through the metal fuselage, but by the time the wing did let go, "all the other usual suspects" had put in their appearances: low wind noise; nose noticeably high; controls (especially stick) getting sloppy; etc. Subsequent to checking out in the ship, I found it "intellectual fun" to mess around with it in slow flight "trying to find the burble." Abrupt departure from controlled flight - yes, indeed! "No warning?" - not by a long shot. The nose was not noticeably high in either glider (20 C or 26E); the wind noise was subdued, but both gliders were very quiet, and the change in noise was very small; there was no burble or "butt feel"; the controls were light but not unusually so; and the wing "departure" was not abrupt - I simply ran out aileron, and the wing would start downward. I'm guessing the inside wing tip doesn't stall, but can't be sure about that. Stick quickly a little bit forward restored aileron authority? The normal spin recovery works fine; even quicker was moving the flap lever forward to the first negative flap position. I don't recall if only stick forward was enough. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
On Sat, 26 Nov 2016 21:16:47 -0800, Eric Greenwell wrote:
Bruce Hoult wrote on 11/26/2016 12:40 AM: On Saturday, November 26, 2016 at 6:50:46 AM UTC+3, Eric Greenwell wrote: Bob Whelan wrote on 11/22/2016 9:06 PM: True, before the wing "let go" there was (almost always) an absence of aerodynamic burble felt through the stick or one's butt or merely "drummed" through the metal fuselage, but by the time the wing did let go, "all the other usual suspects" had put in their appearances: low wind noise; nose noticeably high; controls (especially stick) getting sloppy; etc. Subsequent to checking out in the ship, I found it "intellectual fun" to mess around with it in slow flight "trying to find the burble." Abrupt departure from controlled flight - yes, indeed! "No warning?" - not by a long shot. The nose was not noticeably high in either glider (20 C or 26E); the wind noise was subdued, but both gliders were very quiet, and the change in noise was very small; there was no burble or "butt feel"; the controls were light but not unusually so; and the wing "departure" was not abrupt - I simply ran out aileron, and the wing would start downward. I'm guessing the inside wing tip doesn't stall, but can't be sure about that. Stick quickly a little bit forward restored aileron authority? The normal spin recovery works fine; even quicker was moving the flap lever forward to the first negative flap position. I don't recall if only stick forward was enough. The ASW 20 manual says applying full negative flap should be the first spin recovery action and will often be sufficient for recovery. IME that worked well and since, also IME, immediate recovery from an incipient could cost 300 ft and add 40kts, full negative flap is always a good idea since that also gives you the greatest Vne. In case you're wondering, mine departed twice from a thermal turn with no warning I could detect. Both times I was thermalling at a bit over 45 kts in flap 3 (zero flap) in a well-banked turn. It was something I couldn't replicate intentionally: I wonder if it could be connected with microturbulence in the thermal. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Downwind to final turns | Jonathan St. Cloud | Soaring | 18 | June 7th 15 02:19 PM |
Base to Final - Fatal | Orval Fairbairn[_2_] | Piloting | 0 | August 8th 10 03:23 AM |
The Art of Racing - Final Turn.jpg (1/1) | Mitchell Holman[_4_] | Aviation Photos | 0 | February 27th 10 12:42 PM |
Final Approach, pt 3 - KFME final.jpg (1/1) | Mitchell Holman[_3_] | Aviation Photos | 0 | April 8th 09 12:56 PM |
Turn to Final - Keeping Ball Centered | skym | Piloting | 224 | March 17th 08 03:46 AM |
