"USA friendly"?
Does that mean going back to the 1960s-style 4-wire scheme with one brake light if you're using the turn signals? When changing to LEDs, it's easy to maintain the amber turn and red brake lights, and even add features like white reversing light. Personally completed the mod on three Cobra trailers in the USA. Try looking he http://www.ebay.com.au/sch/i.html?_o...ights&_sacat=0 Any USA glider trailer going to Benalla will need proper lighting. 4-wire and red turn signals are illegal. Jim |
J4, Harbor Freight
http://www.harborfreight.com/4-inch-...ght-93263.html Very bright. I have had these for 5 years at least and absolutely no issues. DL and 22 also have them. You may need to enlarge the hole in the back of the trailer, other than that it is an easy swap. |
On Tuesday, November 22, 2016 at 8:22:52 PM UTC-5, Mitch Deutsch wrote:
J4, Harbor Freight http://www.harborfreight.com/4-inch-...ght-93263.html Very bright. I have had these for 5 years at least and absolutely no issues. DL and 22 also have them. You may need to enlarge the hole in the back of the trailer, other than that it is an easy swap. J4, I agree with Mitch! If you have a Harbor Freight near you... Best deal on the planet. (Bright LED) sealed units. That is my 2000 euros worth. |
I switched to led tail lights after being reared ended on I-85. I added a third led brake light up on the fin that was made for an ambulance. Etrailer.com had the module that makes the third brake light come on only when braking, and I got a module from a motorcycle shop that strobes it three times before staying on. It's quite a light show back there. Dont know if it will repell boarders or mesremise them on the way in. But I feel better about it.
On Monday, November 28, 2016 at 10:01:18 AM UTC-8, SF wrote:
I switched to led tail lights after being reared ended on I-85. I added a third led brake light up on the fin that was made for an ambulance. Etrailer.com had the module that makes the third brake light come on only when braking, and I got a module from a motorcycle shop that strobes it three times before staying on. It's quite a light show back there. Dont know if it will repell boarders or mesremise them on the way in. But I feel better about it. It will, no doubt, attract the inebriated like a both to a flame! :c) |
One suggestion I have is to add reflective tape to the back of the trailer.
I think the narrow width of the trailers including the spacing between tail lights might make the trailer appear farther away than it is. I think the more reflective material makes it appear brighter, which subconsciously may make it appear closer, so they will stay further back. It helps the trailer be seen quicker too. Also the wiring does not fail or come unplugged and even works when just parked. I have pieces of the reflective tape along the back, one white piece up the vertical fin, then pieces on the fenders, and the sides of the trailer. http://www.etrailer.com/Trailer-Ligh...cs/RE418T.html Chris |
Cobra trailer seal replacement--any previous experience? | John Duke | Soaring | 4 | October 5th 15 08:03 PM |
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! | flyingmr2 | Soaring | 4 | November 16th 10 02:11 AM |
Cobra trailer weatherstrip replacement | Larry Goddard | Soaring | 0 | November 25th 09 05:26 AM |
Cobra Trailer Replacement Wheel | Chip Bearden | Soaring | 5 | September 29th 09 08:35 PM |
Cobra Trailer Axel Replacement | Carter | Soaring | 7 | July 7th 04 02:06 PM |
