Pre-Preg
Old December 6th 16, 10:58 AM posted to rec.aviation.soaring
Ross[_3_]
Default Pre-Preg
On Tuesday, 6 December 2016 08:45:13 UTC+1, Fraser Wilson wrote:
Three further points with pre preg;-
1-Uni directional (UD) pre-preg, which is extensively used in wings, is
difficult
to form into compound curves;- it wrinkles
2-stray fibres, with pre-preg stray fibres can puncture the vac bag. The
wing
skins don't come out of the moulds until after the wings have been fully
glued
together. It's a bad day to discover a single stray fibre has killed the
vacuum
during the cure of a skin and you've just glued it to a good
spar/skin/installed
controls etc
3 - wet lay up wings post cure at 60C, normally out of mould. Pre-Preg
cures
at least 80C maybe hotter but this must be done in the mould. This means
the part and mould thermal expansion must be closely matched and the
longer the part , the more compound curves, the more difficult this
becomes.
Dry fibre resin infusion probably offers the best way forward as it can
provide
similar fibre fractions to pre preg but without the above and earlier
mention
drawbacks.
Fraser
I tend to disagree with most of that.
UD is difficult on complex shapes yes, but what is complex about a wing? It is basically straight. If you can laminate it with wet laminate, you can do it with prepreg.
You would cure the skins then glue the rest in. Well, this would be my approach. The spar can be co-cured in there if you like. Makes for easy small steps in manufacturing.
Similar way to the concept behind a F1 car. Outersking, honeycomb and inserts, innerskin.
Don't see the issue with postcure. No need for it to be done in the mold with Prepreg. We were postcuring suspension to 180-220 deg C out of the mold and had no issues. They were cured at 130 to start with.
As far as thermal expansion goes, why not make your molds out of tooling prepreg? Works like a charm, and if you have a decent glider you will make plenty of gliders out of the mold and you will always have the same shape. Beats having to rework your molds every couple of years
Old December 8th 16, 06:43 PM posted to rec.aviation.soaring
J. Nieuwenhuize
Default Pre-Preg
Op dinsdag 6 december 2016 11:58:23 UTC+1 schreef Ross:
Not really. Wing skins need 45/-45 fibers. Easy enough to put in a single tapered wing, but multiple tapers, fairings or wing tips are pretty awkward for either prepregs or thick BIAX/TRIAX.
Fuselage is worse.
Pretty expensive to make such a mold since you need a plug that can withstand that temperature too. Solid aluminium requires major adjustment (thermal expansion during cure), inconel is $$$.
That's one of the biggest advantages of infusion. Cure at 30C or so, join parts etc and pull from the molds. Then, with a very slow ramp-up (5C/hour) you can postcure to 100-120C and you have a plane that can be painted any color and won't need rework for spar bumps and other annoying issues.
Old December 8th 16, 11:04 PM posted to rec.aviation.soaring
Fraser Wilson[_2_]
Default Pre-Preg
wing?
can=
do it with prepreg.
=20
t=
awkward
Fuselage is worse.
mold
mol=
tooling
make
shape.
withsta=
(thermal=
p=
(5C/hour)=
any
I definitely would not take Ros's recommendation of co curing the wing
skins
and spars in one operation . This is just what SH got badly wrong on the
Discus wings when they tried to co cure the caps to the wing skins but
found
they couldn't ensure a satisfactory bond to the spar web when they bonded
the skins together;- was it 70 odd wings sets scraped?
As for a partial cure on a wing cover, remove from mould and final cure at
high temperature, I'm very dubious. In order to assemble the wing skins
together to get the right twist and fit the wing skins must be held to a
high
level of precision. Added to this an individual wing skin is an unbalanced
layup I.e two thick 45's, foam, and one thin bid so its ripe for thermal
distortion. However when the top skin and bottom skins are bonded it
becomes balanced across the wing section. As for the justification that it
works on a 30 (or so) cm part therefore it must work on an 8m I will make
no
further comment.
Yes of course it's possible to build a wing in pre-preg but why? The mould
has
to be made from a more expensive material, more expensive energy is
required to heat it to higher temperature and more expensive manhour time
is required to do all the inter leafing so as to avoid the wrinkling.
Fraser
Old December 9th 16, 05:15 PM posted to rec.aviation.soaring
Soartech
Default Pre-Preg
On Monday, December 5, 2016 at 2:23:59 PM UTC-5, Jonathan St. Cloud wrote:
For the guys with an engine weight does make a difference. Imagine if the 100 pounds of engine and fuel were offset by construction methods that lowered the empty weight of the glider by even 50-70 pounds. YOu would functionally have the same wing loading range as a pure glider.
Jonathon is describing my Apis M 15 meter! Only 500 lbs. total including the engine, prop, starter, battery, etc. Has carbon in the wing spar and other areas.
