Advice on motor glider wanted - FES - Jet - Engine
Old December 10th 16, 07:35 PM posted to rec.aviation.soaring
Default Advice on motor glider wanted - FES - Jet - Engine
Before you buy a jet powered glider, consider the noise level. Our neighbors would shut down our Gliderport if we allowed them to use their engines in the area.
Tom
Old January 3rd 17, 05:21 PM posted to rec.aviation.soaring
Doug B
On Friday, December 9, 2016 at 9:00:05 AM UTC-5, J W wrote:
Seeking advice for a cheapish motor glider but a good investment is
more important.
Was considering the newer types like the 13.5 metre Mini LAK, Silent 2
and HPH Shark.
Concerned that there are very few registered and certified in the UK so
may not be a good investment?
Like the idea of short span, low weight, carbon fibre construction as I’m
not so young and will be flying from rough grass strips. Fly for fun and
not in to competitions.
Would consider electric sustainer but think an engine or jet will be
preferable for range, allowing time to explore mountains and wave.
Suggestions welcomed, Thanks.
I'm new to these jet engine sustainers but I'm interested as well. I have a few major concerns: From what I can gather, they have limited run times, like 10 minutes. Also nobody seems to be saying what the TBO is on these little jets. It might be as low as 50 hours but I'm not sure. And, what is the overhaul cost and therefore, what is the hourly cost of operation?
Old January 3rd 17, 06:01 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I believe the overhaul time is 25 hours, at least for the HpH gliders.
Old January 3rd 17, 06:53 PM posted to rec.aviation.soaring
Paul Ruskin[_2_]
The HpH ones run as long as you have fuel left - maybe 30-40 mins at a reasonable power setting. Time to overhaul is 50 hours, which at the rate I use mine is going to be somewhere between 10 and 20 years. Cost is said to be a few hundred euros - it's basically looking at the bearings.
Paul
Old January 4th 17, 03:48 PM posted to rec.aviation.soaring
Dan Marotta
Jets are cool, no doubt, and highly reliable, but they're very noisy
and, at the speeds gliders fly, very inefficient. I don't know how they
cost compared with a Wankel or piston engine, but I wouldn't have one.
The novelty will wear off.
My $0.02...
more important.
and HPH Shark.
Dan, 5J
Old January 4th 17, 05:17 PM posted to rec.aviation.soaring
krasw
The inefficiency comes from simple single stage turbine without bypass and low operating temperatures (compared to real turbofans).
Old January 7th 17, 06:31 PM posted to rec.aviation.soaring
Paul Ruskin[_2_]
Noise can certainly be an issue, and you wouldn't want to use them much near your home site. But for us glider pilots, efficiency is not a big issue (we don't use it enough to worry). However, they have a very distinct advantage over a piston or wankel, and that's the lack of drag when you extend them.
That means that your commit height is much lower - people I know with conventional engines have to start them above 1000 ft AGL (some use considerably higher) and be downwind on a suitable landing area in case they don't start. With a jet, there's effectively no extra drag, so waiting until 500 ft AGL is perfectly feasible - or you can be further away from the field. That's the difference between completing a flight and not doing so, surprisingly often.
For me, at the moment it's a toss up between jet and FES - though I suspect within a few years FES will win out as battery technology gets better.
Paul
Old January 7th 17, 08:10 PM posted to rec.aviation.soaring
Dan Marotta
One problem I've seen is getting low away from a landable area following
flight in very cold air, e.g., wave. Whereas my Stemme has very little
increase in drag during engine start, and it starts quickly and
reliably, there's a requirement not to use much power until the oil
temperature reaches a certain level. Even with cowl flaps closed, that
can take 5 minutes or more to achieve. Fortunately, with power just
above idle, the Stemme has little to no decent.
Having flown turbojets in Alaska and turbofans in the lower 48, I don't
recall any cautions about oil temperature, though good sense should
prevail. There should be enough temperature for oil to circulate. The
jets would start and run just fine at -40 deg F.
Paul
Dan, 5J
Old January 7th 17, 11:13 PM posted to rec.aviation.soaring
AS
Dan, as far as I know, the small jets we are talking about here or at east the one I looked at seriously in an ASW-20CLJ do not have any oil circuit. The main bearings are lubricated by the jet fuel which is fortified by turbine oil.
Uli
Motor Glider Wanted-Ohio [email protected] Soaring 0 December 2nd 13 05:46 AM
Engine maintenance of a motor glider kd6veb Soaring 0 October 13th 13 05:57 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
wanted prop and motor popeye Home Built 0 March 15th 06 08:46 AM
FIRST MOTOR GLIDER ? Vorsanger1 Soaring 3 March 31st 04 06:03 AM
