The wench launch comment was meant for another newsgroup!
How dangerous is winch launching went compared to aero-tow? In the States most launches are aero-tow. Those that know me, also know you would never see me launch a wrench, as experience has taught me never pick up a tool. On Friday, December 9, 2016 at 2:23:31 PM UTC-8, Dan Marotta wrote: Sew, ewe did not really mean two say "wench", then? On 12/9/2016 1:29 PM, Jonathan St. Cloud wrote: Damn autocorrect meant wrench launching. On Friday, December 9, 2016 at 12:02:52 PM UTC-8, Dan Marotta wrote: Wench launching can be very dangerous, especially if she's heavy and your aim is poor... On 12/9/2016 9:19 AM, Jonathan St. Cloud wrote: So how dangerous is wench launching compared to aero-tow? I only had enough wench launches to remove the "aero-tow only" off my ticket and that was years ago. On Friday, December 9, 2016 at 7:45:05 AM UTC-8, Don Johnstone wrote: At 08:24 09 December 2016, Pete Smith wrote: No, the position changes subtly. On my cirrus and N2 it is at the lower left of the stick box quadrant, o the N3 in question and later gliders it is in the upper left. Please read the accident report and its conclusions. The accident described in the report was not so much of an issue when Earlier ASW,17, 18,19,20 were designed and built. Same applied to SH. The accident is directly related to more powerful winches. The same situation would develop with less powerful winches but it took much much longer. There was more of a ground run to recognise the wing on the ground and the acceleration was much less which meant that when it went wrong it went wrong much slower with more time to react. Not so with a modern powerful winch, when the problem occurs it goes wrong very quickly, probably too quickly for any chance for a meaningful reaction. What is described has always happened from time to time, the only difference is that it did not start killing people until the winches got powerful. -- Dan, 5J -- Dan, 5J |
On Friday, December 9, 2016 at 8:45:05 AM UTC-7, Don Johnstone wrote:
At 08:24 09 December 2016, Pete Smith wrote: No, the position changes subtly. On my cirrus and N2 it is at the lower left of the stick box quadrant, o the N3 in question and later gliders it is in the upper left. Please read the accident report and its conclusions. The accident described in the report was not so much of an issue when Earlier ASW,17, 18,19,20 were designed and built. Same applied to SH. The accident is directly related to more powerful winches. The same situation would develop with less powerful winches but it took much much longer. There was more of a ground run to recognise the wing on the ground and the acceleration was much less which meant that when it went wrong it went wrong much slower with more time to react. Not so with a modern powerful winch, when the problem occurs it goes wrong very quickly, probably too quickly for any chance for a meaningful reaction. What is described has always happened from time to time, the only difference is that it did not start killing people until the winches got powerful. Muddled thinking, Don. All winches have throttles so they produce no more power than the winch operator chooses. If the winch seems too powerful, you're problem is with the winch operator, not the winch. Did "powerful" winches cause a wing drop and subsequent ground loop? Highly unlikely. The problem is far more likely to be with pilot training and general winch operations. Wings go down on winch launch for three main reasons. One, excessively slow acceleration allows a wing drop before the pilot gains aileron control - same as with aero tow. The difference is with a CG hook an ensuing ground loop is going to be more violent. It's much safer to get the glider up to aileron control airspeed in the minimum time. Two, with a fast accelerating winch, should the pilot begin the ground roll with aileron input, they will take effect suddenly forcing a wing tip to the ground before the pilot can react - consciously centering the stick before the launch starts is critical. Avoiding over-controlling ailerons is equally important. Three, wing "runners" sometimes mishandle the situation. If they are accustomed to aero tow, they will be surprised how quickly the tip must be released. |
On Fri, 09 Dec 2016 20:19:18 -0800, Bill.Daniels wrote:
Three, wing "runners" sometimes mishandle the situation. If they are accustomed to aero tow, they will be surprised how quickly the tip must be released. Two additional points (which you may already do): -train the wing runner to hold the tip from behind (NEVER with fingers round the leading edge). This makes it much less likely that the wing runner can deflect the glider before letting go. -teach wing runners to BALANCE the glider on its wheel, raising or lowering the tip a bit to counter the forces generated by a cross-wind. Done right, you need little more than a finger and thumb on either side of the TE to keep the wing balanced despite gusts. If the wing runner is forcing the wing level against a cross wind, then a wing-drop is almost guaranteed when the tip is released. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Saturday, December 10, 2016 at 5:27:54 AM UTC-7, Martin Gregorie wrote:
On Fri, 09 Dec 2016 20:19:18 -0800, Bill.Daniels wrote: Three, wing "runners" sometimes mishandle the situation. If they are accustomed to aero tow, they will be surprised how quickly the tip must be released. Two additional points (which you may already do): -train the wing runner to hold the tip from behind (NEVER with fingers round the leading edge). This makes it much less likely that the wing runner can deflect the glider before letting go. -teach wing runners to BALANCE the glider on its wheel, raising or lowering the tip a bit to counter the forces generated by a cross-wind. Done right, you need little more than a finger and thumb on either side of the TE to keep the wing balanced despite gusts. If the wing runner is forcing the wing level against a cross wind, then a wing-drop is almost guaranteed when the tip is released. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | Yes, balancing the wing and never just "leveling" it is always a better method - for both winch and aero tow. |
Winch Launch School | Karl Striedieck[_2_] | Soaring | 1 | January 7th 16 03:10 PM |
Winch Launch Fatality | Nyal Williams[_2_] | Soaring | 89 | June 27th 09 08:45 PM |
Winch Launch Fatality | Ed Gaddy[_2_] | Soaring | 3 | June 23rd 09 11:15 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
