On Wednesday, December 14, 2016 at 7:24:17 PM UTC-5, Steve L wrote:
On Wednesday, December 14, 2016 at 4:31:25 PM UTC-6, Andrzej Kobus wrote: On Wednesday, December 14, 2016 at 4:09:10 PM UTC-5, Tango Eight wrote: The Cree XML T6 LED is used in many currently available "bright lights". http://www.cree.com/~/media/Files/Cr...g/XLampXML.pdf About 1000 lm ea at max power. There are many bike lights available that use 2 or more of these, and they are great for seeing where you are going (about like a single car headlight), most have a flash mode for daytime.. I have one that's typical of the breed. None of these are going to be useful for blue sky collision avoidance in aviation. Bright as they are, they simply aren't bright enough. Medium and high intensity obstruction lighting strobes give some indication of what it takes to be clearly visible on bright days at aviation-useful distance. For instance: http://www.flightlight.com/airportli...2.3/5.2.3.html best, Evan Ludeman / T8 Before ordering my newest glider (delivered in 2016) I asked quite a few European pilots about usefulness of Schleicher's strobe lights. I got universal thumb down. As a result my glider has ADS-B in and out instead as well as PowerFlarm. I might add 3M reflective tape to some surfaces to reflect sun. This is a much better solution than low intensity strobe light. Some glider pilots in Europe use this type of reflective tape ("mirror tape"). I saw it available at one of the European gliding stores online. I need to find it again and order it before spring. DG website has an article about this solution; a summary of a study by a University in Europe, if I remember correctly. It was a good read. I'm also a RC glider pilot and have used mirror tape on my models. Don't remember which RC source I got it from ,but it works great! You can see it when the plane disappears in one of those great thermals you've been searching for... Model covering- Trim Monokote is available in chrome and is adhesive backed and quite thin. UH |
https://www.amazon.com/ABN-DOT-C2-Tr...eflective+tape
Unfortunately, I couldn't find the thickness of the tape... On 12/14/2016 3:31 PM, Andrzej Kobus wrote: On Wednesday, December 14, 2016 at 4:09:10 PM UTC-5, Tango Eight wrote: The Cree XML T6 LED is used in many currently available "bright lights". http://www.cree.com/~/media/Files/Cr...g/XLampXML.pdf About 1000 lm ea at max power. There are many bike lights available that use 2 or more of these, and they are great for seeing where you are going (about like a single car headlight), most have a flash mode for daytime. I have one that's typical of the breed. None of these are going to be useful for blue sky collision avoidance in aviation. Bright as they are, they simply aren't bright enough. Medium and high intensity obstruction lighting strobes give some indication of what it takes to be clearly visible on bright days at aviation-useful distance. For instance: http://www.flightlight.com/airportli...2.3/5.2.3.html best, Evan Ludeman / T8 Before ordering my newest glider (delivered in 2016) I asked quite a few European pilots about usefulness of Schleicher's strobe lights. I got universal thumb down. As a result my glider has ADS-B in and out instead as well as PowerFlarm. I might add 3M reflective tape to some surfaces to reflect sun. This is a much better solution than low intensity strobe light. Some glider pilots in Europe use this type of reflective tape ("mirror tape"). I saw it available at one of the European gliding stores online. I need to find it again and order it before spring. DG website has an article about this solution; a summary of a study by a University in Europe, if I remember correctly. It was a good read. -- Dan, 5J |
Here's another 2.1 mm thickness
https://www.amazon.com/JVCC-MPF-01-M.../dp/B003ZCSJIK Where would you put to have max effect with min aerodynamic penalty? I think I read a study that said control surfaces were effective. |
(USA, Arizona) Luke SATR now contained in FAA NFD | Tuno | Soaring | 2 | May 18th 10 03:40 AM |
Self Contained Cambridge FAI Recorder For Sale | ContestID67 | Soaring | 3 | April 6th 07 06:26 PM |
Self Contained Cambridge Recorder For Sale | ContestID67 | Soaring | 0 | February 19th 07 04:55 AM |
Portable GPS: receiver and laptop/palm or selft contained unit | picopirate | Owning | 11 | May 16th 04 11:37 PM |
