Yea...Running out of "gas" is no good no matter the propulsion type
On Monday, January 9, 2017 at 7:07:34 PM UTC-7, Tony wrote:
Yea...Running out of "gas" is no good no matter the propulsion type Indeed...What Tony said!!! |
snip It's just that discussions on this topic often include comments
on the 'infallibility' of the system. My post was intended to give a real world example of why we still need to apply basic gliding principles to this propulsion type, just like the rest of them. CJ Very well put. It is for just the above reason that, though I have a very reliable engine, I never get out of range of a safe landing field and, for me, that means an airport. -- Dan, 5J |
It would depend on the airfield. I don't mind landing on grass and I'd
even take off from it. Likewise I'd land on gravel in an emergency but don't want to take off from it out of concern about damage caused by rocks thrown up by the tires and damage to the carbon prop. I don't want to land in an unprepared field due to the possibility of nosing over and the fact that I wouldn't want to take off from a rough field. Realistically speaking, it's rare to be out of gliding range of a paved airport except for the leg between Cedar City and Minden. Very lonely out there... On 1/10/2017 11:55 AM, Henry wrote: Dan Marotta wrote expansively: though I have a very reliable engine, I never get out of range of a safe landing field and, for me, that means an airport. Won't an airfield do? -- Dan, 5J |
Thanks for the additional detail, CJ. The fact that the motor was run previously in the flight changes the picture significantly. However, it's still not clear why the pilot had to shut down the motor. In your original post, you said the battery was overheating, but the incident report says "battery power was low", which suggests the battery voltage had reached it's minimum. Which was it, over-temperature, or under-voltage? These are two very different things. If it was low voltage, then most likely the battery power was simply exhausted. If it was overheating, that suggests a failure of some sort. An OAT of 86F is not extreme, so it would be surprising to me if the battery overheated. Does the FES have any known limitations on motor run-time? My assumption was that it could safely be run continuously until the battery was empty.
I am also a fan of FES and am considering purchasing a sailplane equipped with it. I hope it's not true that the battery could overheat under such seemingly normal operating conditions. |
On Tuesday, January 10, 2017 at 8:50:49 AM UTC-8, wrote:
...Which was it, over-temperature, or under-voltage? These are two very different things. Not necessarily. I=V/R says that as the battery voltage goes down, the amperage required for specific power level is greater. So when you have a computer-controlled system trying to maintain a commanded power level by regulating current upwards, you can get a situation where low voltage is the direct cause of overheating of specific parts of the system. Full disclosu I'm not an FES expert, but I am an FES reseller. --Bob K. |
The bottom line: Did the FES overheat before the battery was exhausted? CJ, can you give us an answer?
On Tuesday, January 10, 2017 at 10:50:49 AM UTC-6, wrote:
Thanks for the additional detail, CJ. The fact that the motor was run previously in the flight changes the picture significantly. However, it's still not clear why the pilot had to shut down the motor. In your original post, you said the battery was overheating, but the incident report says "battery power was low", which suggests the battery voltage had reached it's minimum. Which was it, over-temperature, or under-voltage? These are two very different things. If it was low voltage, then most likely the battery power was simply exhausted. If it was overheating, that suggests a failure of some sort. An OAT of 86F is not extreme, so it would be surprising to me if the battery overheated. Does the FES have any known limitations on motor run-time? My assumption was that it could safely be run continuously until the battery was empty. I am also a fan of FES and am considering purchasing a sailplane equipped with it. I hope it's not true that the battery could overheat under such seemingly normal operating conditions. My experience self launching the Silent 2 Electro is that Battery temperature has never been an issue. I have once or twice gotten a yellow warning for the motor temp when launching in Uvalde and Kansas on 100ish degF days. Slightly "throttling back" cured that with no issue. Finding a thermal helps a lot too. The power consumption when cruising level is very low and motor temps have never been a problem at all when i've had to cruise on hot days. One of those days was a fairly long cruise in Lithuania where I ran the motor for about 35 minutes: http://www.onlinecontest.org/olc-2.0...htId=495576510 |
Motor Glider Wanted-Ohio | [email protected] | Soaring | 0 | December 2nd 13 05:46 AM |
Engine maintenance of a motor glider | kd6veb | Soaring | 0 | October 13th 13 05:57 PM |
shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 02:05 PM |
wanted prop and motor | popeye | Home Built | 0 | March 15th 06 08:46 AM |
FIRST MOTOR GLIDER ? | Vorsanger1 | Soaring | 3 | March 31st 04 06:03 AM |
