Thoughts on panel upgrade?
Old February 2nd 17, 06:34 PM posted to rec.aviation.soaring
John Wells
Default Thoughts on panel upgrade?
Hi Paul,
Is that a Mini Nimbus? (Or maybe a Standard Cirrus?). Either way, I've just redone my panel on my 1978 Mini Nimbus, and decided to DIY an openvario (www.openvario.org). It runs XCSOAR and integrates nicely with my existing lxnav S7 and FLARM.
Before and after pic he
http://i.imgur.com/LIAgqt2.jpg
I also took the opportunity to clean up all the rats nest of wiring and pneumatics, and made each individual piece of equipment switchable between battery A & B in-flight (without interruption) using a MOSFET switching circuit.
All DIY, other than the pre-fabricated panel blank (not strictly necessary, but the old one was aluminium and I wanted to make it safer)... oh and I bought a FlarmView.
None of this is necessary of course, but you can achieve a lot with a limited budget and some perseverance.
Old February 3rd 17, 03:10 AM posted to rec.aviation.soaring
Paul[_10_]
On Thursday, February 2, 2017 at 12:34:18 PM UTC-6, John Wells wrote:
Hi Paul,
Nice panel, John! I've spoken with a few people about openvario, and gave it a lot of thought. Stefan (stefly.aero) sells a very reasonably priced openvario kit, of which I'm sure you're aware, but others might not be. He has a very nice stick controller for openvario... it'd go real well with your setup!
My glider is a Discus, BTW. I'm going to get the panel painted, put it back together, and fly the **** out of it this summer. I'm pretty new to this stuff, and I'm sure I'll be able to make a more educated decision about panel upgrades next winter. There's so much to consider, with transponders, Flarm, varios, etc. There's also this Kraco 8-track player that I'd like to install, but I'm not sure if I can get it to work with my bluetooth subwoofer! ;-)
Old February 3rd 17, 04:26 AM posted to rec.aviation.soaring
JS
Hi Paul,
Kraco 8-tracks are a bit of a pain, you might look into the Panasonics.
Weight and balance can be a problem, plus the tapes don't easily fit out the vent window where you will feel they need to go.
A friend had overheating problems with his Open Vario. Look into that before starting the project (next year).
Old February 3rd 17, 05:34 AM posted to rec.aviation.soaring
Surge
I built my own XCSoar glide computer (Raspberry Pi 2B) and I added a 40mm DC fan underneath the case running at reduced speed (couple of diodes in series) for ventilation.
The biggest source of heat in my case is the 7 inch, 1000 nit touch screen.
I'm sure an Open Vario case could be modified in a similar way to sort out heat issues. I didn't run into any RFI issues with the fan but YMMV.
Old February 3rd 17, 05:57 AM posted to rec.aviation.soaring
Paul[_10_]
That sounds pretty cool! Does it work well? Do you have any details/photos?
Old February 18th 17, 10:12 AM posted to rec.aviation.soaring
I upgraded to S80 with AHRS, Nano3 and use an android tablet running TopHat - very similar to XCsoar and same formats...pretty happy so far, but I had no logger or flight computer previously. S80/S100 are really good instruments with great support from LXNAV. If interested in x-country flying, fly often, pick the brains of all the experienced pilots and beg or borrow a logger. Google maps is good for assessing the course, but be aware the imagery is dated!
Ventus Panel upgrade Fish Soaring 3 September 12th 06 10:44 PM
Glass panel upgrade to a Turbo Arrow? Tauno Voipio Owning 9 March 12th 06 04:29 AM
panel upgrade from VFR to IFR John Doe Owning 5 September 26th 05 10:05 PM
cost of panel upgrade on bonanza soxinbox Owning 19 October 29th 04 04:35 AM
Beech F-33/B-55 panel upgrade or STC Gordon Rich-Phillips Owning 2 January 14th 04 01:28 PM
