Greetings all. I am in the process of building a new panel for my ASW20C and am interested in dumping the annoying side mounted, goose neck mic, in favor of a panel mounted microphone. I'm also installing a standard plug in for a headset.
I read previous RAS comments on this subject and those who have panel mounted mics spoke favorably about their performance. The problem I found is the referenced websites either no longer exist or I can't seem to find panel mount microphones listed on the site. So, my questions a 1. Is there a domestic retailer? 2. Can anyone direct me to a specific site with panel mounted mics listed? 3. Can an automotive panel mounted mic work, like from a car dealer or O'Reilly's? 4. Other suggestions and recommendations? Thanks everyone. Bob |
If you could safely remove the microphone element from the gooseneck one option would be to find a way to clip the microphone element to the shoulder strap of the seatbelt without compromising the belt. This puts the mic nexr to your head and then it's placed there automaticaly when you buckle in. Using 2-3 of the elastic loops like you find on parachute webbing should work suitably.
What a good idea! I rebuilt the rear mounted microphone in my old plane using a 5/8" goose neck and some special end adapters. I never thought to simply junk the goose neck and attach the microphone to my shoulder harness. The new plane's goose neck is starting to fail the same way the old one did, so I'll definitely give this suggestion a try.
-John, Q3 On Thursday, February 2, 2017 at 11:28:39 AM UTC-5, wrote: If you could safely remove the microphone element from the gooseneck one option would be to find a way to clip the microphone element to the shoulder strap of the seatbelt without compromising the belt. This puts the mic nexr to your head and then it's placed there automaticaly when you buckle in.. Using 2-3 of the elastic loops like you find on parachute webbing should work suitably. |
The problem with panel mounted microphones is to be effective they have to pick up sound several feet away. This is good in theory but the reality is a cockpit is a loud environment. A glider at cruise speeds has vario and wind noise that the microphone will pick up. Most aircraft microphones are designed to work at a few centemeters or less. A good quality gooseneck microphone works very well. Cheap ones are a headache.
On Thursday, February 2, 2017 at 12:26:33 PM UTC-6, Tim Taylor wrote:
The problem with panel mounted microphones is to be effective they have to pick up sound several feet away. This is good in theory but the reality is a cockpit is a loud environment. A glider at cruise speeds has vario and wind noise that the microphone will pick up. Most aircraft microphones are designed to work at a few centemeters or less. A good quality gooseneck microphone works very well. Cheap ones are a headache. I've been using a panel mike in an LS6 for the past 2 seasons and it works better than any other mike I've ever used. Cost about $70. Apparently several other pilots in my club think so too - they are installing them also. Way better than ANY boom mike! Kirk |
On Thursday, February 2, 2017 at 8:18:13 AM UTC-8, Robert Ballou wrote:
Greetings all. I am in the process of building a new panel for my ASW20C and am interested in dumping the annoying side mounted, goose neck mic, in favor of a panel mounted microphone. I'm also installing a standard plug in for a headset. I read previous RAS comments on this subject and those who have panel mounted mics spoke favorably about their performance. The problem I found is the referenced websites either no longer exist or I can't seem to find panel mount microphones listed on the site. So, my questions a 1. Is there a domestic retailer? 2. Can anyone direct me to a specific site with panel mounted mics listed? 3. Can an automotive panel mounted mic work, like from a car dealer or O'Reilly's? 4. Other suggestions and recommendations? Thanks everyone. Bob I have a friend that uses a panel mic in his ASW20. He thinks it's fantastic because its convenient for HIM. I think it sucks because I have to listen to him on the other end. He is usually under modulated, or drowned out by the ambient noise in the cockpit. This can be either wind noise or vario noise. Think twice... |
On Thursday, February 2, 2017 at 12:55:47 PM UTC-8, Matt Herron Jr. wrote:
On Thursday, February 2, 2017 at 8:18:13 AM UTC-8, Robert Ballou wrote: Greetings all. I am in the process of building a new panel for my ASW20C and am interested in dumping the annoying side mounted, goose neck mic, in favor of a panel mounted microphone. I'm also installing a standard plug in for a headset. I read previous RAS comments on this subject and those who have panel mounted mics spoke favorably about their performance. The problem I found is the referenced websites either no longer exist or I can't seem to find panel mount microphones listed on the site. So, my questions a 1. Is there a domestic retailer? 2. Can anyone direct me to a specific site with panel mounted mics listed? 3. Can an automotive panel mounted mic work, like from a car dealer or O'Reilly's? 4. Other suggestions and recommendations? Thanks everyone. Bob I have a friend that uses a panel mic in his ASW20. He thinks it's fantastic because its convenient for HIM. I think it sucks because I have to listen to him on the other end. He is usually under modulated, or drowned out by the ambient noise in the cockpit. This can be either wind noise or vario noise. Think twice... Links to the ones that work are needed. Just flew with 5Z on the weekend and thought that other than the vario being too loud that his panel-mount microphone sounded great. Tom's vario speaker is in the panel, will be relocated and should then be fine. Tom... Which microphone is it? There are several types of microphones, with varying sensitivity, impedance, requirement for phantom power, and polar pattern. Some may not work with your glider radio, some may be too quiet or loud, some may pick up too much wind noise, etc. Jim |
kirk.stant wrote on 2/2/2017 12:16 PM:
.. I've been using a panel mike in an LS6 for the past 2 seasons and it works better than any other mike I've ever used. Cost about $70. Apparently several other pilots in my club think so too - they are installing them also. Way better than ANY boom mike! What's the brand the vendor? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
Dang! My transmissions completely suck rocks - just ask all my flying buddies!
Would love to not have to mess with a boom mike. Will keep an eye on this thread.Bruno - B4 |
On Thursday, February 2, 2017 at 2:16:13 PM UTC-6, kirk.stant wrote:
On Thursday, February 2, 2017 at 12:26:33 PM UTC-6, Tim Taylor wrote: The problem with panel mounted microphones is to be effective they have to pick up sound several feet away. This is good in theory but the reality is a cockpit is a loud environment. A glider at cruise speeds has vario and wind noise that the microphone will pick up. Most aircraft microphones are designed to work at a few centemeters or less. A good quality gooseneck microphone works very well. Cheap ones are a headache. I've been using a panel mike in an LS6 for the past 2 seasons and it works better than any other mike I've ever used. Cost about $70. Apparently several other pilots in my club think so too - they are installing them also. Way better than ANY boom mike! Kirk Kirk's works quite well. I got one for my glider based on the clarity of his. I wouldn't hesitate to install on if your considering it |
| Thread Tools | |
| Display Modes | |
| Panel mounted microphone source? | Morteza Ansari | Soaring | 10 | April 10th 12 03:38 AM |
| Panel mount IFR GPS for training ... | Bud_of_yours | Piloting | 23 | December 24th 06 07:38 PM |
| Delcom 960 Panel Mount....... | [email protected] | Aviation Marketplace | 0 | June 27th 06 04:17 AM |
| manual for garmin 100 panel mount. | Ray Toews | Home Built | 1 | September 11th 05 11:28 PM |
| Panel-Mount ICOM A5 | Ron Wanttaja | Home Built | 2 | July 22nd 05 02:39 AM |
