Wing Loading / climb rate
Old February 13th 17, 07:01 PM posted to rec.aviation.soaring
Bruce Hoult
Default Wing Loading / climb rate
On Monday, February 13, 2017 at 8:50:39 PM UTC+3, Dan Marotta wrote:
If the lifting force exactly matched the weight of the glider then, in
still air, wouldn't the glider not lose altitude? Or are you saying
that the sink rate of the glider is cause by drag?
On 2/13/2017 6:46 AM, Tango Whisky wrote:
Le lundi 13 février 2017 04:52:04 UTC+1, Jim a écrit :
Yes, I have enjoyed slower-flying thermal-working too. It's lots of fun.
My curiosity about wing loading and climb rate really is limited to non-thermalling, non-turning flight. I was wondering about the possible relationship of wing loading to lifting force. Likely an unrealistic circumstance in actual flying though. Just a curiosity.
Well, on a good soaring day, about 70-80% of the flight is non-thermalling, non-turning flight.
And the lifting force always matches the weight of the glider, regardless of wing loading.
As I'm sure you know, lift = weight is exactly true for a powered aircraft in straight and level flight.
It's only an approximation for a glider, where in fact lift plus drag together exactly equal weight. But as the lift is typically 40 - 60 times the drag we usually take a shortcut and ignore that.
In a glider with airbrakes deployed and in a steady speed 45 degree dive lift and drag are equal and both 70.71% of the weight. But that's not how we fly when trying to maximize performance.
Old February 13th 17, 07:16 PM posted to rec.aviation.soaring
Dan Marotta
That's what I was thinking. Ignore the small part of the sum. Thanks,
nice refresher!
Dan, 5J
Why Isn't Vx The Best Rate Of Climb? RandyL Piloting 18 September 28th 06 07:50 PM
figuring Rate of Climb Michael Horowitz Home Built 1 June 19th 05 03:16 AM
Newbie question on Rate of Climb Wright1902Glider Home Built 0 August 17th 04 03:48 PM
Rate of climb Dillon Pyron Home Built 3 May 8th 04 01:08 PM
Climb Rate for DG-600M Steve B Soaring 5 August 25th 03 08:17 AM
