Tow Plane Upsets......
Old April 26th 17, 04:30 PM posted to rec.aviation.soaring
Dan Marotta
Default Tow Plane Upsets......
Just thinking of the physics here and remembering that the problem is
with the upward vector on the tow rope exerting so much force on the
Schweizer release that the tuggie can't release the rope. The following
assumes enough altitude to recover, not early in the tow.
Now, if the tug's tail gets pulled up sufficiently, the force vector on
the rope is more aligned with the longitudinal axis of the tug than the
vertical, thereby relieving the release of the upward (with respect to
the axis) force. Therefore the tug should be able to release as his
nose gets pointed towards the ground. Am I willing to prove this
theory? NO...
Also, if the glider is being pulled down via its CG release, the wing
should be fully stalled given the AoA of the wing in a (near) horizontal
descent with the fuselage level to the horizon. Application of rudder in
the glider should immediately induce a spin allowing the combination to
gently descend like a maple seed. Am I willing to prove this theory? NO...
And, when the tug hits the ground, the glider is free of the downward
pull of the rope and the resulting fire will generate a thermal allowing
the glider to climb away safely. Am I willing to prove this theory? NO...
On 4/26/2017 6:26 AM, Tango Eight wrote:
On Wednesday, April 26, 2017 at 4:11:04 AM UTC-4, Tango Whisky wrote:
Le mercredi 26 avril 2017 03:45:04 UTC+2, George Haeh a écrit :
Yes, I know that's taught, but does anybody put the student high so that
release is required.
Just as with spins, there's a difference between being told what to do -
and
actually going into the situation.
Putting a student high so that a release is required would be plain stupid and reckless behaviour of an instructor.
Any exercise needs to be planned in a way that the student has some room for error, and that the instructor can recover the situation if the student finally fails to do so.
In a high position there is no such margin. There are situations which just can't be trained.
Bert
TW
What can't be trained is the dangerous divergent situation. Agreed on all else.
-Evan / T8
Dan, 5J
Old April 26th 17, 04:17 PM posted to rec.aviation.soaring
Dan Marotta
I was once air retrieving someone from an airport over 50 NM away from
Moriarty. We briefed thoroughly before takeoff that I would level off
and reduce power slowly at 10,000'. He later told me that, as I was
leveling off, he was looking inside the cockpit and missed it and lost
sight of me. He immediately released, which was great, but it was late
in the day and he did not have glide home. I told him to land and I
would give him another tow for free but he said he'd try for home. I
flew along with him looking for and guiding him to thermals. ...And he
beat me back to Moriarty. But he released immediately on losing sight
of me.
and
Dan, 5J
Old April 26th 17, 12:50 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Quote:
Originally Posted by George Haeh View Post
We train boxing the wake, cannot release and slack rope recovery, and
expect
demonstration of some or all of these items on checkouts.
Hands up anybody who trains release when high on the towplane?
If students have never done this, how can we expect them to do it when
needed before or after license?
Good point and it is obviously not part of any training syllabus of which I am aware. If done at altitude....2 or 3K feet and done only momentarily I feel it would be a reasonable thing to do BUT only with the towpilots knowledge that it is going to be done and with some kind of signal immediately before hand. I am confident I can get out of anything I can get into with sufficient altitude. Then again this would depend on the willingness and preparation of the tow pilot. JMHO.
Walt
Old April 26th 17, 02:05 PM posted to rec.aviation.soaring
On Wednesday, April 26, 2017 at 8:43:08 AM UTC-4, Walt Connelly wrote:
expect
Walt
Walt Connelly
This tow pilot will not agree to putting aircraft out of control at any altitude.
UH
Old April 26th 17, 05:51 PM posted to rec.aviation.soaring
Bob Kuykendall
UH
I can imagine that a severe kiting upset of the type under discussion could put a towplane uncomfortably close to its negative load factor limits. It might also expose the tug's tailplane to loads beyond those for which it was designed or tested.
--Bob K.
Old April 26th 17, 06:17 PM posted to rec.aviation.soaring
George Haeh
Well yes, we really don't want to go to extreme attitudes, nor do would
anybody half sane contemplate practicing getting high on the towplane until
approaching release altitude.
The idea is to build the muscle memory of releasing well before the
towpilot
has gotten to maximum up elevator.
We do want to give the towpilot adequate margin.
Old April 26th 17, 06:49 PM posted to rec.aviation.soaring
Bob Kuykendall
On Wednesday, April 26, 2017 at 10:30:05 AM UTC-7, George Haeh wrote:
Well yes, we really don't want to go to extreme attitudes...
I definitely agree that we should teach recognition and remediation.
But I also think that the main point here is that a true kiting incident is a divergent condition such that, once established, can easily escalate at a rate beyond human control. So we have to be careful about how we teach it.
--Bob K.
Old April 26th 17, 07:34 PM posted to rec.aviation.soaring
Jonathon May[_2_]
is
a
it.
--Bob K.
I'm not a power/ tow pilot so this could be rubbish,but
Could an alarm be fitted at 90%back stick just to remind tug pilots just
how
much up elevator they are using to prevent gradually drifting into a
potential
dangerous situation from which there will be no escape.
Old April 26th 17, 08:31 PM posted to rec.aviation.soaring
Bruce Hoult
I would like to know what happens if you have a 1000+ ft aerotow rope and cause the glider to "winch launch" behind the tug.
I have a hunch that very very bad things start to happen long before there's any significant upward angle on the rope. Such as the tug virtually stopping mid air and stalling/falling.
Slow Tows and Upsets 7C Soaring 0 March 4th 14 11:41 PM
F-35: Second test plane powers up, but first plane stays grounded Mike[_7_] Naval Aviation 1 October 29th 07 09:40 PM
the plane! the plane! protect it without photons. Spike Home Built 0 December 17th 05 03:28 AM
Plane down - NASCAR team plane crashes... Chuck Piloting 10 October 28th 04 12:38 AM
Kit plane boom with Sport Plane rules Dave Home Built 1 February 4th 04 02:37 PM
