Tost Ring Failure
Old June 12th 17, 04:20 AM posted to rec.aviation.soaring
AS
Default Tost Ring Failure
On Sunday, June 11, 2017 at 7:37:42 PM UTC-4, Sean Franke wrote:
On Sunday, June 11, 2017 at 1:00:04 PM UTC-7, Benedict Smith wrote:
The failures I have seen are not in the tost ring pair at the glider end of
strop but the ones further down that connect the strop to the drogue or on
either side of the weak link (a circular ring that the strop is spliced to
and is
coupled to the oval Tost link with the quick release flat), as these are an
integral part of the quick release link I assume that they should be a
genuine
Tost part, but several I have seen are welded construction and don't have
any
visible markings on them. (This is in the UK)
At 15:52 11 June 2017, Tango Eight wrote:
On Sunday, June 11, 2017 at 11:34:20 AM UTC-4, howard banks wrote:
Would some kind soul who really knows please tell us whether genuine
Tost
rings are ever(a) welded or (b) oval?
The correct rings are stamped LN 65091 on the big ring. The most recent
production also have TOST stamped on them. The big ring is oval, the
little ring is round.
30+ years ago, there was a different Tost ring set in use. It is not
stamped with the LN 65091 designation. It is obsolete and should not be
used.
best,
Evan Ludeman / T8
Tost Connecting Rings do not have a weld. Tost states that type certification stipulates that every Tost tow release must be operated only with a ring pair meeting the LN 65091 aeronautical standard. Connecting ring pairs must be stamped with the manufacturer's name and the standard number.
WELDED RINGS ARE GENERALLY PROHIBITED. Use of welded rings voids tow release warranties. Welded rings cause damage to tow releases. Undersized rigs can lead to tow release jamming.
Connecting rings must be visually checked and measured at regular intervals. Rings pairs that deviate from standard dimensions must be replaced.
See a ring pair picture he http://wingsandwheels.com/aircraft-p...tow-rings.html
Sean Franke
See my note above. The picture clearly shown the weld in the large ring....
Tow ring attachment? Waveguru Soaring 7 May 25th 15 07:50 AM
Tost release failure Bill D Soaring 24 August 20th 13 10:49 AM
TOST Release Failure - Two Uncommanded Release's [email protected] Soaring 11 October 13th 12 10:23 AM
red ring of death larryo keeffecom Soaring 1 February 29th 12 03:50 PM
VW Flywheel O-ring [email protected] Home Built 0 April 6th 08 09:57 PM
