Unable to Update PowerFLARM Portable Firmware
Old September 4th 17, 02:27 AM posted to rec.aviation.soaring
Dave Springford
Default Unable to Update PowerFLARM Portable Firmware
As I understand, the portable does not update when presented with a new FW on the SD card upon power up. You have to go into the menu and select the update FW item.
Old September 3rd 17, 02:22 PM posted to rec.aviation.soaring
Did you try going under "menu-info-update" to force it to look for the update?
Old September 3rd 17, 06:09 PM posted to rec.aviation.soaring
Dan Marotta
I didn't see that option.Â* I'll look if the freshly formatted SD card
doesn't work.
Dan, 5J
New PowerFLARM firmware 6.40 Dan Daly[_2_] Soaring 15 September 5th 17 06:23 AM
PowerFlarm Firmware Karl Kunz[_2_] Soaring 9 March 15th 17 02:44 PM
PowerFLARM Portable Firmware Update: 6.02 Paul Remde Soaring 15 April 10th 15 03:13 PM
Portable PowerFlarm hardware update kd6veb Soaring 8 March 22nd 13 10:44 PM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 01:50 AM
