ADSB visibility with non certified GPS
Old September 24th 17, 03:33 AM posted to rec.aviation.soaring
Dave White[_2_]
Default ADSB visibility with non certified GPS
If I read the Trig website correctly the tt21 is approved for adsb-out just about everywhere on the planet except the USA. So if someone brings their certified glider from their home country are they legal to fly in the USA or must they comply with USA requirements?
Old September 24th 17, 04:02 AM posted to rec.aviation.soaring
Darryl Ramm
Is there light at the end of this rat hole? But the answer is going to be comply with US regulations. The more detailed answer of course is you are going to discuss this with an FAA representative.
And there is no such thing as just a TT-21 install for ADS-B out.What is the GPS source? I expect many gliders flying outside the USA who have ADS-B Out have a COTS GPS source, and that likely a worse issue, who knows what they set SIL etc. to. Not only will that not be valid in a certified equivalent aircraft in the USA but it may well get you noticed by the feds.
Stratus / Foreflight ADSB 6X Soaring 5 December 17th 13 09:34 AM
ADSB is only the start... Martin Gregorie[_5_] Soaring 0 October 1st 09 01:27 PM
Santa and ADSB Mal Soaring 0 December 15th 06 07:42 PM
Non-certified parts for a certified plane? Dico Owning 10 August 22nd 06 03:11 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
