In message , Typhoon502
writes (ArtKramr) wrote in message ... It has nothing to do with any of that. The more missions you fly the worse the odds of survival. How commited you are is irrelevant. I think this is patently, demonstrably false. The more missions you fly, the more experience and maturity in the role you gain. And thus, the more likely you are to avoid making the mistake or error that can compromise your survival. To a point, but it depends on mission, role and threat. That's why veteran fighter pilots would regularly make mince out of rookies sent out to take them on. True, but how does an "experienced bomber pilot" holding formation in the box avoid barrage AAA? Can't change course or speed - you're in *formation*. What else can you do except hold on and hope? Tactical fighters (and ground combat troops, interestingly) have a well documented survivability curve, rising rapidly in the early stages as they learn to recognise and honour the threats (and according to some, dropping towards the end of fixed-length tours - combat fatigue or overconfidence? Don't know, but it's at least claimed) But those are combatants with - literally - a lot more room for manoeuvre. Flying formation bombing raids was rather more like Napoleonic infantry forming square under artillery fi each roundshot fired at the formation could kill or maim four or five men, and individual skill made no difference at all to the enemy gunners' point of aim and the flight of the shot. Experience improved your chances of coming back after damage, fending off fighter attack and avoiding loss by error (those weren't easy or forgiving aircraft) but did nothing to reduce the odds of an AA shell exploding within lethal distance of your aircraft. That's why you take your experienced soldier, sailors, Marines, and pilots and put them into training roles to impart some of that knowledge into the empty heads of their trainees, so that maybe the learning curve for the new ranks won't be as steep. Worth doing just about everywhere. And it's definitely a matter of commitment. A committed soldier or pilot learns more, trains harder, and works more to ensure the survival of the unit, and therefore himself. Also no argument. -- He thinks too much: such men are dangerous. Julius Caesar I:2 Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
Subject: Bush Flew Fighter Jets During Vietnam NOT From: (Fred the Red Shirt) [As anything I wrote had already been snipped] The more missions you fly, the more times you get wounded the slimmer the chances of survival are. But you know that, don't you? Arthur Kramer Guess it is all a matter of how committed you are and how important you think the job is you have been assigned to do It has nothing to do with any of that. The more missions you fly the worse the odds of survival. How commited you are is irrelevant. I think whoever wrote that meant that the decision to stay on or take advantage of an opportunity for transfer while still alive depended on the degree of one's commitment. Not that the odds of survival depended on the degree of one's commmitment. As someone who never faced combat I'll not criticize the decision or commitment of anyone who did. -- FF |
From: (Regnirps) Date: 7/15/2004 8:01 AM Pacific Standard Time Message-id: (ArtKramr) wrote: It has nothing to do with any of that. The more missions you fly the worse the odds of survival. How commited you are is irrelevant. I agree, but only if yu look at the ensemble of flights. Each flight is not more dangerous than the next. Every time yu survive, your chances start over on the next mission. Same as rolling dice. Rolling five boxcars in a row doesn't increase the odds that you won't on the 6th throw -- each throw is an independent event. (This assumes a random risk which is an ideal that certainly isn't true, as each mission is different. But how do you measuer how different? Count the holes afterword?). -- Charlie Springer True. But if you roll the same number 5 times in row a crap table, note how everyone is shocked and the house will change the dice.The difference between a mission and a crap table is that at the crap table a bad roll doesn't result in death. And a mixture of targets results in a mixture of odds depending on defenses. So not all missions are equal like dice rolls. But other than that...... Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
Regnirps wrote:
Same as rolling dice. Rolling five boxcars in a row doesn't increase the odds that you won't on the 6th throw -- each throw is an independent event. I'll take issue with this, Charlie. While each throw is statistically independent (assuming honest dice, naturally), the fact that they are honest dice requires that the most common throw be a seven. The more consecutive boxcars you throw, the higher the probability that the next throw will NOT be a 12. Boxcards is not a statistically likely event. Each throw **is** an independent event, but the total population of throws is governed by the overall statistical distribution. Jeff |
(Regnirps) wrote in message ...
(ArtKramr) wrote: It has nothing to do with any of that. The more missions you fly the worse the odds of survival. How commited you are is irrelevant. I agree, but only if yu look at the ensemble of flights. Each flight is not more dangerous than the next. Every time yu survive, your chances start over on the next mission. Same as rolling dice. Rolling five boxcars in a row doesn't increase the odds that you won't on the 6th throw -- each throw is an independent event. (This assumes a random risk which is an ideal that certainly isn't true, as each mission is different. But how do you measuer how different? Count the holes afterword?). Mr Kramer was speaking (correctly) about cumulative probablity whereas the other argument was correct about the probability per event. If you throw the dice twenty times the probability that you'll throw snake eyes is higher than if you only threw them 10 times BECAUSE the probability of throwing snake eyes is the same on each roll. -- FF |
Juan Jiminez is a liar and a fraud (was: Zoom fables on ANN | ChuckSlusarczyk | Home Built | 105 | October 8th 04 12:38 AM |
Bush's guard record | JDKAHN | Home Built | 13 | October 3rd 04 09:38 PM |
Two MOH Winners say Bush Didn't Serve | WalterM140 | Military Aviation | 196 | June 14th 04 11:33 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
