Tow hook for 182
Old March 27th 18, 09:19 AM posted to rec.aviation.soaring
Default Tow hook for 182
On Wednesday, 21 March 2018 19:51:05 UTC+13, wrote:
Hello David
Thank you for information. Maybe I didn't write it clear, but we are not under FAA but under EASA supervision. I've started to communicate with our civil aviation authority how to easiest approve some STC (or different solution) from NZ or from Canada.
Martin
Martin
PM me dmoody365 at... and I'll get you some data for a first look
David
Old March 18th 18, 02:58 PM posted to rec.aviation.soaring
Roy B.
The Schweizer towhook installation on the 182 is done upside down compared to the "normal" tailwheel install. So the whole "glider kiting" phobia issue does not apply. IMO in a dusty environment the Schweizer hook is a better & simpler solution than the Tost units. As previously noted, K&L has them. McFarlane used to sell a similar unit. Good luck.
ROY
Old March 18th 18, 03:03 PM posted to rec.aviation.soaring
On Thursday, October 19, 2017 at 12:25:26 AM UTC-5, Ramy wrote:
Our club is looking for a tow hook for 182, in particular Schweizer (partnumber 0500228-2) which is the STC'd approved hook for the Cessna 182. Any pointers are welcome.
Thanks
Ramy
When the US National Championships were held in Wichita, KS in 1961, Cessna aircraft (also in Wichita) provided a small fleet of towplanes. After that event, the Schweizer tow releases were a given Cessna part numbers and were added to the type design of the aircraft as an optional part. Therefore, it is part of the certification for the airplane; no additional paperwork is required.
Old March 27th 18, 09:12 AM posted to rec.aviation.soaring
Thanks
Ramy
Can anybody tell me if the EASA/Canada Bilateral treats a "Serial" STC differently from a (non-serialised) STC. We recently spent a tidy sum having an additional serial number added to a SSTC (all aircraft involved being on the Canadian register). Further question, can a Canadian SSTC be amended to add aircraft not currently on the Canadian Register. Arcane questions I'm sure, but may assist our ability to support Ramy's enquiry.
David
Old May 3rd 19, 09:31 PM posted to rec.aviation.soaring
Thanks
Ramy
You can use the 1250 kit from Pacific Aerial Tow Hooks https://pacificaerialtowhooks.com/
Old June 25th 19, 12:09 PM posted to rec.aviation.soaring
SA220SO is the STC/
Did you have any luck with EASA?
Thanks,
Milan
Looking for tow hook for C-182 Alexey Sharadkin Soaring 1 December 11th 16 07:37 PM
Tow hook 182 [email protected] Soaring 7 October 26th 15 01:39 PM
Compare/Contrast: CG hook on aerotow vs. CG hook on winch son_of_flubber Soaring 37 June 4th 12 10:40 PM
CG Hook for SGS 2-33 Rusty Soaring 0 November 23rd 05 12:15 PM
Tow Hook 337 for a 150-150 1JH Soaring 3 July 19th 05 06:35 PM
