The ASW 20 seems to have a reputation for bad behavior in some configurations. Is this reputation deserved or overblown? What has been the experience of those who have owned and flown the glider? Are some variants of the 20 better or worse in terms of handling characteristics?
Tom A |
I used to fly an ASW20C (15 m, no winglets) with an aft CoG, and it would spin without any warning. Mowing the CoG forward removed this behavior.
Lateron I owned an ASW20 (A-model with winglets) wich I flew with a 1/3 aft position, and it was completely harmless. Bert TW |
On Sat, 04 Nov 2017 22:55:39 -0700, anklam2 wrote:
The ASW 20 seems to have a reputation for bad behavior in some configurations. Is this reputation deserved or overblown? What has been the experience of those who have owned and flown the glider? Are some variants of the 20 better or worse in terms of handling characteristics? I had an early ASW-20 (s/n 34), the so-called A series, with the two stage landing flap. Twice it departed in a thermal turn without any warning, zero flap (position 3) 40-45 degree bank, flying at 45 kts. Both times It recovered after a 1/4 turn, though 300 ft lower and now at 80 kts. The second time it happened I tried to reproduce the same behaviour after arriving back home in late afternoon with plenty of height in hand, but was unable to get it to spin similar from turns at the same or a slightly lower airspeed. I was forced to conclude that this was either idiosyncratic behaviour of my particular ASW-20 or it had something to do with micro-turbulence in the thermal. Apart from that I had no issues with its handling once I'd learnt to fly a flapped glider properly and not to add 5 kts to approach speed for luck since that made it want to float into the next county after rounding out. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Sunday, November 5, 2017 at 1:55:40 AM UTC-4, wrote:
The ASW 20 seems to have a reputation for bad behavior in some configurations. Is this reputation deserved or overblown? What has been the experience of those who have owned and flown the glider? Are some variants of the 20 better or worse in terms of handling characteristics? Tom A The '20 got a poor early reputation due to it's spin characteristics when flown with aft CG. When it came out it was very common for pilots to fly with far aft CG to try to get more performance. I have extensive experience in A and C versions. Something around 1200 hrs or so. When flown at, or aft of the manufacturer's aft CG point they both depart and spin quite quickly. A pilot can be easily surprised by this. That characteristic does not surface, from my experience, with the CG forward of the 80% point. It will still spin, but doesn't snap the same way. Flown well behind manufacturer's limit, is, in my opinion, very dangerous. There is negligible performance lost at 75-80% and interestingly enough, the trimmer isn't even needed. I flew my 20C with the trimmer taped off the entire time I owned it. I also found that external seals, in addition to the usual internal seals, seems to make the tendency to drop a wing at high angles of attack less. I'm pretty sure this is due to spanwise flow in the trailing edge cove that gets trapped by the seals. Winglets, again from my experience, make the stall and wing drop more docile, but make the spin, as it develops, more abrupt. There is a reason these ships have remained popular and desirable. FWIW UH |
On Saturday, November 4, 2017 at 10:55:40 PM UTC-7, wrote:
The ASW 20 seems to have a reputation for bad behavior in some configurations. Is this reputation deserved or overblown? What has been the experience of those who have owned and flown the glider? Are some variants of the 20 better or worse in terms of handling characteristics? Tom A Thanks for all the responses; very helpful. Tom A |
On Sunday, November 5, 2017 at 12:55:40 AM UTC-5, wrote:
The ASW 20 seems to have a reputation for bad behavior in some configurations. Is this reputation deserved or overblown? What has been the experience of those who have owned and flown the glider? Are some variants of the 20 better or worse in terms of handling characteristics? Tom A Second what the others have said about spins with the CG too far back. I have 20a serial #18. With full thermalling flap (actually hardly ever needed).. Mine will drop a wing upon stall. Just a normal wing drop that can be countered with forward stick and a bit of opposite rudder. Essentially identical behavior to my 301 Libelle with full positive flap. So, nothing abnormal for early high performance gliders. After slipping my 301 to landings for the last 20 years, I love the 20's glide path control. Full landing flaps and full divebrakes make for parachute steep landings. However, landing flaps on the 20a can lead to trouble for the incautious. One has to be absolutely sure of having the landing site made, especially in full landing flap. Not advisable to move the landing flap handle once established on short final. Coming out of full flap will cause the glider to drop in hard, or worse, lead to a stall/spin if one pulls back to try to stop the fall. |
Interesting thoughts about a glider that has been around--and much loved--since the late 1970s. I have less than 10 hours in two ASW 20s (a very early one and a later A) so I can't speak from experience. When it began to develop a bit of a reputation back in the 1980s, I heard a story/rumor/speculation that the fabric tape used to cover the flap/wing joint might be to blame if it bulged out into the airflow during slow flight and triggered separation. No idea if that was true but subsequent models used Mylar seals (and/or beryllium copper for at least one ASW 20B) and I suspect most early models have been fitted with Mylar. If I were buying a '20, I'd look at the seals--and CG--closely just to be careful.
Chip Bearden |
On Sunday, November 5, 2017 at 2:23:24 PM UTC-5, wrote:
...I heard a story/rumor/speculation that the fabric tape used to cover the flap/wing joint might be to blame if it bulged out into the airflow during slow flight and triggered separation. IIRC that tape bulging caused aileron flutter, but not other problems. Regardless, the tape should have been replaced with mylar on all 20's. Hank??? |
On Sunday, November 5, 2017 at 2:44:28 PM UTC-5, Dave Nadler wrote:
On Sunday, November 5, 2017 at 2:23:24 PM UTC-5, wrote: ...I heard a story/rumor/speculation that the fabric tape used to cover the flap/wing joint might be to blame if it bulged out into the airflow during slow flight and triggered separation. IIRC that tape bulging caused aileron flutter, but not other problems. Regardless, the tape should have been replaced with mylar on all 20's. Hank??? Flutter was associated with seal tapes. Flaps fluttered more than ailerons if I remember correctly. Mylar is a good improvement and was standard on B and C. Flaps on A go down far enough to be tough on Mylar on bottom when in full landing flap. UH |
| Thread Tools | |
| Display Modes | |
| Sparrowhawk handling | Hartley Falbaum[_2_] | Soaring | 26 | October 16th 15 01:25 AM |
| Glider Handling on Tow | John Carlyle | Soaring | 42 | November 14th 13 04:41 PM |
| Jantar Standard 2 & 3 handling | Bryan Poehler | Soaring | 2 | October 22nd 12 09:57 PM |
| Ventus bt handling | Jorge Antonio Blanco Montagut | Soaring | 9 | May 27th 11 11:48 PM |
| Austria/SHK/SB5/V-tail handling | Marc Teugels | Soaring | 1 | June 26th 04 12:48 PM |
