Paint removal from canopy?
Old November 30th 17, 12:49 AM posted to rec.aviation.soaring
Darryl Ramm
Default Paint removal from canopy?
On Wednesday, November 29, 2017 at 9:04:05 AM UTC-8, Waveguru wrote:
Is there a solvent that will remove rattle can paint without damaging the plexy?
Boggs
I would use LP Aero polish. Wash canopy first with water and detergent. Straight rubbing directions, no circles. It will help help polish up the canopy anyhow. http://www.lpaero.com/accessories.html
Old December 2nd 17, 08:05 PM posted to rec.aviation.soaring
Waveguru
I got all of the over spray off with Meguiar's A1216 Cleaner Wax - Liquid. The canopy looks better than it did before!
Boggs
Old December 3rd 17, 02:00 AM posted to rec.aviation.soaring
I will hazard a guess all this removal depends on how clean the canopy is as well as whether or nor it is routinely waxed or otherwise "prepped".
An old crazed canopy that has no real maintenance done will make any paint removal harder, a canopy that has wax or similar will be easier.
YMMV.
Yes, start with a safe removal, then work your way up as needed.
No, I would NOT recommend anything that is/has a solvent other than maybe rubbing alcohol.
Lots of water is always good.......
Canopy Ejection and Canopy Lanyard Casey[_2_] Soaring 6 April 12th 16 05:09 PM
Rust removal? noel.wade Soaring 22 March 2nd 09 06:22 AM
Adhesive removal [email protected] Soaring 8 May 2nd 06 02:37 PM
Trailer paint removal Chris Davison Soaring 13 September 3rd 04 10:42 PM
Removing paint from canopy Jason Restoration 4 November 12th 03 09:22 PM
