Relieving in flight
Old December 21st 17, 05:50 PM posted to rec.aviation.soaring
Default Relieving in flight
I use a quart sized zip lock baggie with a toddler size diaper folded inside of it (inside out, with the absorbent part exposed). This takes care of the danger of the bag getting punctured, since the diaper soaks up the liquid (in a couple of minutes). Yes it's a bit of a distraction when using it, but I can choose when to use it, during a quiet part of the flight (cruise rather than thermal).
And I never throw it overboard - bad PR!
Old December 21st 17, 07:17 PM posted to rec.aviation.soaring
WB
I do about the same: Make "piddle packs" out of doubled ziplocs containing the pad from an adult diaper. That will completely absorb at least two good urinations. Also absorbs barf (yeah, after more than 30 years at this, I still occasionally get airsick).
Outlanded at a lonely little county airport once and got thoroughly interrogated and searched by a very young, completely freaked out sheriff's deputy (female version of Barney Fife). She was asking if I had weapons or drugs onboard when she spotted the "used" ziploc baggy pee bomb protruding from under the seat rim. She snatched it up and it was about two beats before she realized what she was holding. That significantly dampened her enthusiasm for further searching.
Old December 21st 17, 07:33 PM posted to rec.aviation.soaring
I use a male adhesive catheter and "leg bag" for myself, but make up a few "guest" baggies for use in our duo. Those are just quart ziplocks with a heaping teaspoon of Sodium Polyacrylate (the magic absorbent in diapers). You can get it on Amazon, a pound will last many lifetimes.
Unused this would definitely get the attention of the sheriff. White powder in a plastic bag, huh...
RR
Old December 21st 17, 07:34 PM posted to rec.aviation.soaring
John Cochrane[_3_]
Problems with pee tubes include freezing up, and pee causing tail components to rust. I've had both happen. A catheter and bladder both exploding at 17,500 over the whites is not that fun! That's what led me to an onboard system.
All this joking aside, having some pee system and the ability to use it in the cockpit should be mandatory before going off cross country. If you can't pee, you won't drink, and if you don't drink, you can't think.
John Cochrane
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files Ian Strachan Soaring 0 July 20th 14 07:28 PM
New 18m Class ship - First Flight - The JS1 starts proving flight phase [email protected] Soaring 2 December 14th 06 02:06 AM
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown,New Jersey Dave Vioreanu Piloting 0 April 22nd 05 02:55 AM
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown, New Jersey Guy Elden Jr Piloting 0 April 21st 05 04:37 PM
Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? Scott Ferrin Military Aviation 0 April 3rd 04 08:47 PM
