On Monday, January 8, 2018 at 5:51:42 PM UTC-8, Darryl Ramm wrote:
I have no idea what point you are trying to make or what you are responding to. What information in my original link is not clear or in accurate and why? You wrote that I could not put a TN72 into my certified glider. That is incorrect per this brochure. Tom |
On Monday, January 8, 2018 at 8:55:31 PM UTC-8, 2G wrote:
On Monday, January 8, 2018 at 5:51:42 PM UTC-8, Darryl Ramm wrote: I have no idea what point you are trying to make or what you are responding to. What information in my original link is not clear or in accurate and why? You wrote that I could not put a TN72 into my certified glider. That is incorrect per this brochure. Tom Darryl's post doesn't say such a thing - not even close. He does say (selected extract below) 1. All gliders can install a TT21 or TT22 transponder with a TN72 to be used as a "TABS" (Traffic Awareness Beacon System) device.....These installations cannot be used to comply with 2020 ADS-B Out mandates...but is visible to PowerFLARM 1090ES In... ....likely over many tens of miles, is visible to ATC ....is visible to certified panel mount ADS-B In traffic systems, and will make the aircraft an ADS-R or TIS-B client for ADS-B ground services (but which PowerFLARM can't receive). 2. Certified gliders that want to meet the 2020 ADS-B Out mandate can't use a TN-72 for that....They would require a Trig TN-70 actual TSO-C145c GPS source.... Reads petty clear to me and is consistent with the quoted text from Trig. So yes, you can put a TN72 into your certified glider but you still cannot fly into ADSB designated airspace, only in areas where equipage is voluntary [for a glider]. David |
Jan 16 Update | DHeitm8612 | General Aviation | 0 | January 14th 05 02:43 AM |
Dec 21 Update | DHeitm8612 | General Aviation | 0 | December 19th 03 02:24 AM |
Dec 14 Update | DHeitm8612 | General Aviation | 0 | December 12th 03 03:42 AM |
Dec 7 Update | DHeitm8612 | General Aviation | 0 | December 5th 03 03:22 AM |
Nov. 23 Update | DHeitm8612 | General Aviation | 0 | November 21st 03 05:08 AM |
