Evan, the data was found refering to a 6 cylinder cht that we had in our pawnee. Also reconfirmed on a 200hp Stinson also with 6 position cht. Doubt away, the technique does work, been using it for 30 years, have never cracked a cylinder. And regarding your bird dog (glorified 170) venting fuel, I hope your not towing with topped off tanks, that extra weight costs you time and money in the long haul unless where you operate doesn't have handy fuel available. We always operated with 3/4 tanks but note we were flying in extreme density altitude conditions.
I will agree the slip angle likely makes minimal difference in engine cooling.
I WILL say a high slip angle makes the tug come down pretty fast with not a lot of airspeed, adding some "G load" at the same time helps as well. Airspeed (straight on or angled) is still flow through the cylinder fins. So.......lower speed and slightly reduced airflow can only help, the slip adds to sink rate. That IS part of the goal....correct? Turnaround time, lack of adding to maintenance..........right? |
Debunking Glider Spoiler Turns Causing Spin Thinking | [email protected] | Soaring | 135 | January 7th 18 03:01 AM |
Debunking 911 | The Endeavor | Naval Aviation | 0 | April 22nd 09 12:23 PM |
Aerodynamics acording to Myth Busters! | cavelamb himself[_2_] | Home Built | 51 | November 4th 07 06:56 PM |
Avoiding Shock Cooling in Quick Descent | O. Sami Saydjari | Owning | 32 | January 21st 04 04:32 AM |
The myth that won't die. | Roger Long | Piloting | 7 | December 19th 03 06:15 PM |
