Looping a standard cirrus
Old January 16th 18, 03:39 AM posted to rec.aviation.soaring
Key Dismukes
Default Looping a standard cirrus
On Monday, January 15, 2018 at 4:57:46 PM UTC-8, wrote:
Who has done a loop in a standard cirrus? Any comments or hints. Currently getting some acro training with the goal of looping my cirrus.
I started to do a loop long ago in my standard Cirrus, but as i put the nose for speed started to get some flutter from the flying stabilizer. Quickly (but oh so gently) aborted the loop.
Old January 16th 18, 03:48 AM posted to rec.aviation.soaring
Check the operating manual. If the manual doesn’t tell you how to do the loop, don’t do it. The manual for any good glider will have a section that explains the procedure and entry speed for a loop.
Old January 16th 18, 05:24 AM posted to rec.aviation.soaring
It’s rated for loops. All it says is that the entry speed is 97 knots
Old January 16th 18, 09:42 AM posted to rec.aviation.soaring
Dave Nadler
Accidentally or intentionally?
If you don't know what I'm talking about, you should...
Old January 20th 18, 02:10 AM posted to rec.aviation.soaring
Burt Compton - Marfa Gliders, west Texas
What Dave says . . .
The smoothest soaring pilot I ever flew with was Johnny Byrd (R.I.P), multiple time champion and member of our US World Team. He described to me about flying in very rough air when his Standard Cirrus sailplane pitched up vertical, so he pulled it around into a loop. He figured that was the best option to avoid a falling "tail slide" which might break the sailplane. It possibly pitched up so suddenly due the all-flying horizontal tailplane. I do not believe that he ever looped any other aircraft except for that "accidental" loop.
Johnny Byrd was cool cat. Quiet demeanor and always helpful. I learned a lot from his sharing of his knowledge and I miss him so . . .
Burt
Marfa, TX
Old January 20th 18, 03:53 AM posted to rec.aviation.soaring
Michael Opitz
At 02:10 20 January 2018, Burt Compton - Marfa Gliders, west
wro=
te:
=20
What Dave says . . .=20
(R.I.P),
multi=
described to me
abou=
up
ve=
best
o=
It
tailplane.
I=
that
"acc=
idental" loop. =20
learned a
lot from his sharing of his knowledge and I miss him so . . .=20
Burt
Marfa, TX
I miss 30 a lot as well... He was my team-mate....
RO
Old January 20th 18, 03:06 PM posted to rec.aviation.soaring
Doing a loop is well within the flight envelope of almost all modern (20 years) gliders. A low stress figure that is fun to fly.
BUT...you should have a verified, accurate G-meter.
AND...the greatest risk about flying aerobatics is knowing what to do when a figure is failing. Learning how to safely recover from a figure that is going bad is the true value of aeraobatic training. Most low time acro pilots I have flown with do not know what to do when they stall out at the top of a loop. They freeze at the controls while they are trying to think their way out of the situation. While they are thinking the aircraft is gaining speed VERY RAPIDLY. It takes only the blink of an eye to blow through your Vne. All of our current acro gliders have Vne around 150 knots. That gives us a large gap between the 100 knots we typically start and end a loop at and the Vne. Your glider Vne is so close to the entry/exit speed of a loop that it would be hard to give you a thumbs up on doing a loop in that aircraft.
Get acro training in an acro aircraft and be happy.
Old January 16th 18, 02:26 PM posted to rec.aviation.soaring
Nick Kennedy
Oh come on, If Bruno can do it... Finish your Aero training and go for it, whats the worst that can go wrong? Wings or elevator comes off? Tailslide? Thats what your parachute is for BTW, practice getting out in all conditions and go for it, the glider IS certificated for the maneuver, what could got wrong? Pilots do loops all the time.
Old January 16th 18, 07:37 PM posted to rec.aviation.soaring
I have looped an early, all-flying stab Cirrus, Mini Nimbus, and Janus A. Seriously locked down my control hand/arm on my leg as the elevator stick pressure in all of them is pretty neutral and it would be pretty easy to pull too hard.
Old January 17th 18, 05:29 PM posted to rec.aviation.soaring
Hi,
I would recommend good training before trying to loop the cirrus, as the cited entry speed of 97 knots is quite near to VNE of 119 kt. Very easy to get out of it with a lot of speed.
Don't do it without a G-meter installed.
Regards
Stefan
Standard Cirrus Walt Connelly Soaring 10 December 31st 11 04:03 PM
Standard Cirrus Walt Connelly Soaring 23 March 20th 11 03:14 AM
Standard Cirrus C-Hook Randy[_2_] Soaring 26 September 26th 08 10:24 PM
Standard Cirrus Don Burns Soaring 0 January 10th 07 05:24 AM
F/S - Standard Cirrus 75 Bob Soaring 0 October 4th 04 12:23 AM
