Steve: Off field landings are all well and good, but there is simply nowhere to land on the north side of the Lake Tahoe basin. Zero, zilch, nada. One landing has been made on the golf course, but it looks mighty chancy to say nothing of the golfers.
Both: The general idea of a last turnpoint with minimum altitude, as practiced in the SGP, has a lot of merit, when there are no good fields close to the airport for blown final glides. It would also allow finish lines such as we had at Uvalde without some of the amazingly close calls we also had at Uvalde. John cochrane Yes, John I know that. I wasn't responding to Jon's post about crossing the lake (We were typing at the same time I guess). Landing out surely always requires a place that's suitable. Jumping to the problem of what to do about Truckee... How about simply using a 30 mi finish cylinder. That would allow us to have a full day racing task there. If you can't get home due to west wind washout, you just land Minden or Carson without any disrupting effect on the scoresheet and without any daredevil temptations. The tugs at Minden would be set on ready alert for late hour missions or next morning missions if you bring your toothbrush. Or, for the crewed amongst us, crews might even be pre-dispatched to Minden. Just a thought. |
On Wednesday, February 7, 2018 at 7:18:12 PM UTC-8, Steve Koerner wrote:
Steve: Off field landings are all well and good, but there is simply nowhere to land on the north side of the Lake Tahoe basin. Zero, zilch, nada. One landing has been made on the golf course, but it looks mighty chancy to say nothing of the golfers. Both: The general idea of a last turnpoint with minimum altitude, as practiced in the SGP, has a lot of merit, when there are no good fields close to the airport for blown final glides. It would also allow finish lines such as we had at Uvalde without some of the amazingly close calls we also had at Uvalde. John cochrane Yes, John I know that. I wasn't responding to Jon's post about crossing the lake (We were typing at the same time I guess). Landing out surely always requires a place that's suitable. Jumping to the problem of what to do about Truckee... How about simply using a 30 mi finish cylinder. That would allow us to have a full day racing task there. If you can't get home due to west wind washout, you just land Minden or Carson without any disrupting effect on the scoresheet and without any daredevil temptations. The tugs at Minden would be set on ready alert for late hour missions or next morning missions if you bring your toothbrush. Or, for the crewed amongst us, crews might even be pre-dispatched to Minden. Just a thought. The problem with a 30 mile finish cylinder is it virtually guarantees no one returns to Truckee. You have the blessing of a dedicated crew that will go get you where ever you land. That's pretty rare these days. ![]() We can have a full racing day if the weather cooperates for once. Our "normal" good weather there allows a finish into Truckee at 5 or 5:30. the OLC guys will often land at 6 or 7. The problem we have had for the last couple of years is the weather gods are looking at the SSA racing schedule and playing practical jokes on us. |
On Wednesday, February 7, 2018 at 2:12:32 PM UTC-6, Steve Koerner wrote:
Landing off field is just part of soaring. I agree Steve - every time one takes off, they need to be prepared for an off field landing. Actually, it's a fun part of soaring. Not for me - besides the increased risk, it is a total pain in the ass. Time, retrieve, disassembly in a field, etc. Did I mention lost contest points ![]() I think the risk of landing out is a key "turn off" for potential soaring pilots and potential contest pilots. (Maybe#1.) I am a huge fan of the training one gets through the SSA Badge process. Lou |
Yes, a lot of the point of hard deck is to move the whole decision-making chain upward. Now you treat 2000' AGL as you used to treat 1000' AGL, at least for sporting purposes.
On whether it actually will change behavior, this thread has produced a classic example of cognitive dissonance -- holding two contrary ideas in mind at one time. A) No pilot is so dumb they're thinking about points below 1000'. (Both positive and negative -- the lure of getting home is so strong they will screw around down low without points, and pilots are so sensible they wouldn't screw around down low just for points) B) Pilots will spend all their time watching the instruments trying to figure out if they have busted the minimum. Just to draw out the logic, that behavior only results if you think that pilots indeed are concerned entirely about points, and making all decisions at 550 feet with that in mind. General: We have spent too much time on "low saves." That's really not the issue. As I looked at many traces of off field landing accidents in contests, what's clearly going on is very low and late decision making. Whether hoping for a low save or for other reasons, failing to follow the usual advice that below 600 feet forget about everything else and land is the key issue. In not one of the traces I have seen - which all ended in damage -- did the pilot start a sensible downwind at 600 feet, base, final. It's all mad dash low altitude and low speed maneuvering. John Cochrane |
The Melting Deck Plates Muddle - V-22 on LHD deck.... | Mike | Naval Aviation | 79 | December 14th 09 06:00 PM |
hard wax application | Tuno | Soaring | 20 | April 24th 08 03:04 PM |
winter is hard. | Bruce Greef | Soaring | 2 | July 3rd 06 06:31 AM |
It ain't that hard | Gregg Ballou | Soaring | 8 | March 23rd 05 01:18 AM |
Who says flying is hard? | Roger Long | Piloting | 9 | November 1st 04 08:57 PM |
