cockpit exit assist for older pilots
Old March 12th 18, 12:00 PM posted to rec.aviation.soaring
Default cockpit exit assist for older pilots
You didn't specify whether survival after egress was required.
https://www.youtube.com/watch?v=MPolRUz3_qo
Old March 12th 18, 06:21 PM posted to rec.aviation.soaring
Dan Marotta
Or the Yankee Extraction System http://www.ejectionsite.com/yankee.htm.
Oh, no - that would be for bailout.
Dan, 5J
Old March 12th 18, 06:37 PM posted to rec.aviation.soaring
Dan Marotta
Better still - VIDEO https://www.youtube.com/watch?v=8Yw8g1Soigk.
Dan, 5J
Dan, 5J
Old March 12th 18, 10:56 PM posted to rec.aviation.soaring
Renny[_2_]
On Monday, March 12, 2018 at 12:37:26 PM UTC-6, Dan Marotta wrote:
Better still - VIDEO.
System.
Dan, 5J
Dan, 5J
Dan - I like it....Here is another potential solution...It does require a very long glider...
https://www.youtube.com/watch?v=MsREqsNS_yI
Old March 12th 18, 12:27 PM posted to rec.aviation.soaring
Gianni Isotope
Sorry, I'm sure this is a real concern for aging pilots, but the first thing that came to mind is a large tube of BENGAY®.
Old March 12th 18, 12:49 PM posted to rec.aviation.soaring
OK, seriously.......
Are you talking a pilot getting in and out or older people/sorta disabled that go for rides?
What ship/ships? What is required in an ASK-21 will be different than a 2-33.
For glass ships, what works on a side hinge canopy may not be the best for a front hinged.
Old March 14th 18, 06:28 PM posted to rec.aviation.soaring
While all good ideas (some rather extreme and not good for day to day), the OP has not stated if this is for an owner that has an issue or "rides", nor has the ship been mentioned.
For some of you, wellllll......, good ideas, but likely the ATF (in the US) may want to talk to you about the devices you are using......LOL.......
Ejection seats.....are some proposing that getting out of the craft also means a chute repack each time?!?! Sounds expensive for a DD.......
Could make some great YouTube videos though.........;-)
And peeps comment on wormburners, low saves, etc.........
Old March 15th 18, 01:04 AM posted to rec.aviation.soaring
George Haeh
For a small fraction of the price of an installed NOAH system, you could
buy a
copy of Aging Backwards - and get working on a daily stretching program.
Use it or lose it.
Old March 12th 18, 02:53 PM posted to rec.aviation.soaring
On Sunday, March 11, 2018 at 8:47:50 PM UTC-5, wrote:
What devices and or methods are available to assist older pilots in exiting sailplane cockpits (on the ground)?
Our club has a median age of 60 and several older, but proficient, pilots have difficulty getting out of the club 1-26E and club K-6E. The air bladder may be a solution. Availability? Giving rides in the club 2-33 necessitated the use of a small kitchen step ladder for older or challenged passengers.
Old March 12th 18, 05:04 PM posted to rec.aviation.soaring
Dan Marotta
I'm planning to set up the Bow Flex to improve my ability to lift myself
straight up using only my arms.Â* The Stemme's cockpit is pretty deep
and, with a parachute and survival vest (lot of wilderness out here),
it's becoming a struggle.Â* It would also be nice to lose about 15 pounds...
Dan, 5J
OLDER PILOTS PERFORM BETTER, STUDY FINDS Larry Dighera Piloting 16 March 21st 07 02:11 AM
How do you exit a F-22 cockpit? John Dallman Naval Aviation 1 May 28th 06 02:51 PM
How do you exit a F-22 cockpit? Mike Naval Aviation 11 May 25th 06 08:01 PM
Older Pilots and Safety Bob Johnson Soaring 5 May 21st 04 01:08 AM
Glass Cockpit in Older Planes Charles Talleyrand Owning 2 May 20th 04 01:20 AM
