cockpit exit assist for older pilots
Old March 17th 18, 02:18 AM posted to rec.aviation.soaring
Scott Williams
Default cockpit exit assist for older pilots
On Friday, March 16, 2018 at 6:20:38 AM UTC-5, wrote:
If you have a good Dive Shop in the area and go in and explain what you are trying to do they might be about to modify a BC (buoyancy compensator) that you could sit on and then inflate to lift up. They certainly will have bottles of different sizes, small ones used to emergency air could be your air source. May be a bit of a stretch, but if you have a good shop could be worth the conversation time spent.
Kevin
92
what about a lawn tractor inner tube with the valve core removed and a can of tire inflator (without any sealer) might cost less than $50 and be small and portable.
OLDER PILOTS PERFORM BETTER, STUDY FINDS Larry Dighera Piloting 16 March 21st 07 02:11 AM
How do you exit a F-22 cockpit? John Dallman Naval Aviation 1 May 28th 06 02:51 PM
How do you exit a F-22 cockpit? Mike Naval Aviation 11 May 25th 06 08:01 PM
Older Pilots and Safety Bob Johnson Soaring 5 May 21st 04 01:08 AM
Glass Cockpit in Older Planes Charles Talleyrand Owning 2 May 20th 04 01:20 AM
