No it is not April 1.
On Friday, April 6, 2018 at 12:38:51 PM UTC-4, Jonathan St. Cloud wrote:
I fly from an operation that uses chain links on their tow ropes. One of the pilots I know who 'has seen it all' likes to point out: 'lots of time, it is the stupid **** that kills people'. Simple avoidable stuff kills people. Chain links on tow ropes is a perfect example. |
Thanks for all responses. Seeing how easily a chain link can slip of the Tost release I find it hard to believe that anyone would tow with a chain link.
My concern was more from the fact that my Tost hook seem to have more freedom than other Tost hooks, enough to make the difference on the ground with a chain link but not enough freedom for a Tost ring to slip through. Ramy |
I seem to remember a similar thread that mentioned minimum diameter of the Tost ring. Not the overall size, but the diameter of the metal that is captured by the release itself. The recommendation was to check the ring with calipers or a micrometer to make sure that the ring had not worn down to the point that it could be inadvertently pulled out of the mechanism. I have not been able to find reference to a minimum size. Anybody know the specification?
On Saturday, April 7, 2018 at 5:47:48 AM UTC-6, wrote:
I seem to remember a similar thread that mentioned minimum diameter of the Tost ring. Not the overall size, but the diameter of the metal that is captured by the release itself. The recommendation was to check the ring with calipers or a micrometer to make sure that the ring had not worn down to the point that it could be inadvertently pulled out of the mechanism. I have not been able to find reference to a minimum size. Anybody know the specification? http://wingsandwheels.com/tost-double-tow-rings.html |
I seem to recall that back in the '80s Tost rings cost that much, if not
more.Â* A bargain by today's standards! I also recall lots of folks using chain links on ground handling ropes to move their gliders around on the airport.Â* This was before the wide spread use of tow bars.Â* My partner and I used a Tost ring on our ground handling rope. On 4/7/2018 8:06 AM, Eric Bick (ZN7) wrote: On Saturday, April 7, 2018 at 5:47:48 AM UTC-6, wrote: I seem to remember a similar thread that mentioned minimum diameter of the Tost ring. Not the overall size, but the diameter of the metal that is captured by the release itself. The recommendation was to check the ring with calipers or a micrometer to make sure that the ring had not worn down to the point that it could be inadvertently pulled out of the mechanism. I have not been able to find reference to a minimum size. Anybody know the specification? http://wingsandwheels.com/tost-double-tow-rings.html -- Dan, 5J |
TOST Release Failure - Two Uncommanded Release's | [email protected] | Soaring | 11 | October 13th 12 10:23 AM |
Anyone have a Tost release? | noel.wade | Soaring | 5 | June 10th 10 04:36 AM |
FS Tost E85 Release | scooter | Soaring | 0 | March 7th 06 02:31 AM |
FS Tost E85 Release | scooter | Soaring | 0 | November 22nd 05 01:11 AM |
Tost release on L-19? | Roy Bourgeois | Soaring | 2 | November 29th 04 10:24 PM |
