Source of green donuts for instrument tubing installation?
Old April 10th 18, 02:37 PM posted to rec.aviation.soaring
Default Source of green donuts for instrument tubing installation?
"Has anyone ever tried a short piece of shrink-sleeve - "
Probably not a good idea. It will help the sealing, but the contraction when heated does not impart a lot of actual compressive force. Also, you will need a razor knife to get it off, which will likely damage the tubing.
I like these:
https://www.amazon.com/Wingsmoto-Tub.../dp/B012MBHEHQ
8.5 mm may not be exactly the size you need.
pvc tubing/sleeve source? Jim Burns Owning 4 September 28th 06 03:36 AM
pvc tubing/sleeve source? Jim Burns Home Built 4 September 28th 06 03:36 AM
Recommended source for 4130 sheet and tubing? Michael Horowitz Restoration 3 April 16th 06 07:23 PM
source for clear+red instrument tubing John W Soaring 8 November 1st 04 01:19 PM
source for aluminum tubing with rounded corners? Kyler Laird Home Built 3 June 1st 04 03:07 PM
