A Simple Question About LiFePO4 Batteries
Old May 25th 18, 04:27 PM posted to rec.aviation.soaring
Default A Simple Question About LiFePO4 Batteries
On Saturday, May 19, 2018 at 8:38:15 AM UTC-4, Tango Eight wrote:
On Friday, May 18, 2018 at 11:05:47 AM UTC-4, wrote:
Interesting - the discharge voltage goes down with lower temperatures - isn't that the opposite of lead-acid? At the least, lead-acid needs higher CHARGING voltages when it's cold.
How well does a microAir radio, which is finicky at low SLA voltages, do with a "12V" LFP battery, which offers a slightly higher voltage on the discharge curve?
Those voltage curves apply to 0.5C discharge, i.e. a two hour discharge rate. The primary reason for the change in behavior at low temperature is increasing internal resistance, not decreasing open circuit voltage. Compare to similar curves for SLA batteries, if you can find them (they'll probably be at slower discharge rates).
Under real world glider use, LFP batteries perform better than SLA batteries in cold conditions. But don't recharge below 0 C.
T8
The claims that one should not charge LiFePO4 batteries below 0 deg C - but charge as fast as you want at +1 C - don't make sense. I've read that there are issues at low temperatures with the lithium plating the graphite anode (or is it the cathode?) instead of being absorbed into it, due to slower reactions. OK, but then the charging rules should be something like:
* up to C/5 at 10 C
* up to C/10 at 5 C
* up to C/20 at 0 C
* up to C/50 at -5 C
but I've never seen anything like that. And "0 deg C" is too round a number to be quite correct for anything other than freezing water. What gives?
Old May 20th 18, 02:58 AM posted to rec.aviation.soaring
My Xcom radio contunually shows “low bat” wth Lithium battery until about 8 hours when it becomes normal.
I suspect the high voltage triggers the “low bat” signal.
LifePO4 batteries for motorgliders - are we there yet? Chris Soaring 13 January 9th 16 03:43 PM
LiFePO4 Batteries on sale. [email protected] Soaring 20 December 9th 15 05:34 PM
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
Copyright 2004-2025 AviationBanter.
