Color Platforms for Top Hat/XCSoar
Old May 31st 18, 10:57 PM posted to rec.aviation.soaring
Dan Marotta
Default Color Platforms for Top Hat/XCSoar
That worked really well!Â* Not as bright as my ClearNav, but certainly
readable.Â* With my sunshade installed it should really work well.
I was really tired the glacially slow performance of the Nexus 7 2012
with Android 5.1.1 so I found a way to root it and then flashed a pared
down custom ROM.Â* It now boots in 40 seconds, has no bloatware, and is
really fast.Â* The ROM is SLIMKat.Â* Look it up if you're a tinkerer.
On 5/31/2018 3:41 PM, Dan Marotta wrote:
Thanks, I'll try that!
I just tried the sunshade outside in the NM sunshine and it works
well.Â* I think I'll start it up again, check the brightness, and go
back outside.Â* I'll report back.
On 5/31/2018 2:12 PM, wrote:
Â*Â*Â*Â* I have a Nexus 7 which would also work for running the program but
Â*Â*Â*Â* it's absolutely useless in direct sunlight.Â* I considered making a
Â*Â*Â*Â* sun shade for it, but found THIS
I use the Nexus 7 all the time and never have a sunlight issue - Are
you positive you went into setting and have it manually set to full
brightness?
The default allows the tablet to adjust.... it needs to be set on
full. Best $130 bucks I have spent.
I have 2 Nexus 7's and both work great!
WH
Dan, 5J
Pacific War in Color, pt 9 - P 61 in color.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 0 April 5th 17 01:18 PM
Pacific War in Color, pt 8 - P 39-color.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 1 April 4th 17 08:41 PM
Pacific War in Color, pt 8 - P 39s-color.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 0 April 4th 17 01:31 PM
XCSOAR Travis Beach[_2_] Soaring 3 May 24th 08 03:36 PM
Flying platforms/airgeeps David L. Burkhead Home Built 3 January 19th 05 06:33 AM
