Emir, great to see you moving forward on your project.
I expect you already know this, but at the risk of being redundant, I’ll post anyways. Just thickening the skins in the motor bay area won’t restore the torsional stiffness of the boom. When the hole is cut for the doors the boom goes from a closed tube shape to an open “C” shape. This dramatically reduces the torsional stiffness and strength of that area. You can demonstrate it to yourself with a cardboard tube.. The factories get around this by adding a pair of vertical walls in the engine bay to form two closed “D” shaped tubes, essentially restoring the lost stiffness. Good luck with your project. I’m looking forward to hearing how it works out. Best regards, Craig |
Craig,
Thanks for the advice. That is the big issue on the project. Is difficult to obtain the same rigidity of a cone like the boom tail once cut. The reinforcement floor and walls will form 3 different enclosed sections with fibers at 45° from the fuselage line. After the modifications I will test the fuselage with strain gauges to see the new strain distribution and compare them with the original. |
On Friday, October 26, 2018 at 5:34:13 AM UTC-7, Emir Sherbi wrote:
Craig, Thanks for the advice. That is the big issue on the project. Is difficult to obtain the same rigidity of a cone like the boom tail once cut. The reinforcement floor and walls will form 3 different enclosed sections with fibers at 45° from the fuselage line. After the modifications I will test the fuselage with strain gauges to see the new strain distribution and compare them with the original. Emir, Sounds like you've got it covered. It's always interesting to see whether the instrumented prototype matches the modeling. Best wishes, Craig |
Op vrijdag 26 oktober 2018 04:50:09 UTC+2 schreef Emir Sherbi:
Aldo, There will be a very thick floor and sidewalls to reinforce the fuselage structure and that will protect the control rod and cables. If anything get loose it will stay in the motor bay. Regards This project looks amazing. Do you have any idea of a price that you would like to get for selling such a kit? Also, with any kind of fittings, is there any probability of them getting loose? |
![]() This project looks amazing. Do you have any idea of a price that you would like to get for selling such a kit? Also, with any kind of fittings, is there any probability of them getting loose? The price of the kit will be around 17.000 USD depending on controller and battery capacity choices without installation. Now that i left my full time job to continue with this project i can travel to make the modifications by myself. The fastening part of the fittings will be at plain sight. So if you check out them time to time there must be no problems. |
Electric Self Launching System | Emir Sherbi | Soaring | 0 | June 4th 18 04:54 PM |
FES&electric system batteries | krasw | Soaring | 33 | February 25th 17 04:17 PM |
ASW24 - electric valve system | Norbert Gulczynski | Soaring | 1 | January 25th 15 01:13 PM |
Electric Duct Fan (EDF) Self-Launch Glider? | CLewis95 | Soaring | 26 | January 20th 11 06:27 PM |
Electric self-launch sailplane | CH | Soaring | 2 | September 14th 03 01:49 AM |
