![]() Quote:
Dot 5 is a silicone based fluid and is hydrophobic i.e doesn't absorb water. Dot 5.1 is glycol based and is hydroscopic i.e. does absorb water. It's a PITA having the numbering system this way but it means that it's quick and easy (really?) to distinguish between the 2 types of brake fluid that meet the performance standard for Dot 5. Mix them at your peril https://www.lubricants.total.com/brake-fluid-types :-) Colin Last edited by Ventus_a : May 8th 19 at 11:55 PM. |
On Tuesday, July 17, 2018 at 10:38:55 AM UTC-5, Scott Williams wrote:
does anyone know the Parker/Cleveland part number for the brake Disk used on a Grob Twin II fixed gear which used a Cleveland caliper? Glider made about 1981. I'm aware of the Dot 3/4 compatible O-ring used in the caliper. Thanks, Scott Well, to the best of my knowledge, and the Grob 103 twin II manual, and service bulletin OSB 315-17, . the master cylinder was a modified Magura motorcycle part, which might have been original equipment on BMWs, maybe a R100? which uses dot 3 fluid. The original equipment caliper is a Cleveland/Parker Hannifin 30-63A, which has a Buna-N O ring( MS28775-224) for use with petroleum based aircraft hydraulic fluid, I think it was easier and cheaper to change the caliper O ring than to change the master cylinder seals. The "O ring swap" I mentioned was intended to ensure caliper O ring compatibility with the Brake fluid indicated in the flight manual.( dot 3) If someone simply replaced either the caliper or just the O ring with the Cleveland called out part number, this would result in the Cleveland O ring swelling over time. That is something you don't want in a caliper. The ID label on our Grob 103 caliper should be labeled "DOT 3" but is not (Yet). Larry Suter, on rec aviation Jan. 6th 2015 started a thread that covered it better than I. If I'm incorrect, please post. Thanks, Scott |
does anyone know the Parker/Cleveland part number for the brake Disk used on a Grob Twin II fixed gear which used a Cleveland caliper? Glider made about 1981. I'm aware of the Dot 3/4 compatible O-ring used in the caliper. Thanks, Scott if anyone wants a new rubber diaphragm for the round cap, it is BMW motorcycle part number 32 72 1 238 387 good lift, Scott |
does anyone know the Parker/Cleveland part number for the brake Disk used on a Grob Twin II fixed gear which used a Cleveland caliper? Glider made about 1981. I'm aware of the Dot 3/4 compatible O-ring used in the caliper. Thanks, Scott Check and measure the master cylinder bore size, compare the pictures to your component piston and spring. try here, https://www.beemerboneyard.com/mamacykifr3.html good luck |
WTB - used Cleveland 40-78B main wheel | Roy B. | Soaring | 1 | February 19th 18 08:25 PM |
hydraulic disk brake upgrade | shkdriver | Soaring | 2 | June 27th 13 05:41 PM |
ASW-24 Main Wheel Removal | Lauren Rezac | Soaring | 5 | March 19th 12 04:20 PM |
Tost 5“Penta disk brake wheel Mod for Duo Discus | Mike I Green | Soaring | 0 | February 6th 12 09:38 PM |
Tost Disk Brake rebuild? | Paul Cordell | Soaring | 10 | April 17th 08 07:20 AM |
