Dream Panel
As you may already know, I am ordering a new ASH31Mi. I am in the process of coming up with the panel layout and instrument selection. I would love to here from other pilots what they consider to be their dream panel (cost is not an issue).
Tom |
Dream Panel
LX9070 computer with Remote stick, Wifi & AHRS options, KRT2 radio,Trig transponder (w/ADS-B out), 57mm Winter mechanical vario, ASI & altimeter, PowerFlarm feeding Flarmview 2. Solar panel with switching between separate LIpo batteries and ability to run any instrument on either battery and/or charge either battery. Switched gear warn system. Circuit breakers (not fuses). Total Cost about $12,000 USD ROY |
Dream Panel
LX9070 computer with V9 vario, Remote stick, Wifi & AHRS options, KRT2 radio,Trig transponder (w/ADS-B out), 57mm Winter mechanical vario, ASI & altimeter, PowerFlarm feeding Flarmview 2. Solar panel with switching between separate LIpo batteries and ability to run any instrument on either battery and/or charge either battery. Switched gear warn system. Circuit breakers (not fuses), simple compass.
Total Cost about $14,000 USD ROY |
Dream Panel
Whatever you choose (largely personal preference) I'd recommend you have Rex install and wire the panel, rather than the factory. Or do it yourself.
Dream Panel
On Tuesday, July 17, 2018 at 7:36:26 PM UTC-7, Roy B. wrote:
LX9070 computer with V9 vario, Remote stick, Wifi & AHRS options, KRT2 radio,Trig transponder (w/ADS-B out), 57mm Winter mechanical vario, ASI & altimeter, PowerFlarm feeding Flarmview 2. Solar panel with switching between separate LIpo batteries and ability to run any instrument on either battery and/or charge either battery. Switched gear warn system. Circuit breakers (not fuses), simple compass. Total Cost about $14,000 USD ROY Sounds good, except I would go with the Air Avionics ACD (Air Control Display), paired with the KRT2 and VT-01 Mode S transponder (saves 1 panel cutout). And I would add the Garmin GDL 82 ADS-B. I would also use the Air Avionics altimeter (it's awesome!). Schleicher has a thing about circuit breakers (?!). Tom |
Dream Panel
On Tuesday, July 17, 2018 at 9:36:53 PM UTC-7, 2G wrote:
On Tuesday, July 17, 2018 at 7:36:26 PM UTC-7, Roy B. wrote: LX9070 computer with V9 vario, Remote stick, Wifi & AHRS options, KRT2 radio,Trig transponder (w/ADS-B out), 57mm Winter mechanical vario, ASI & altimeter, PowerFlarm feeding Flarmview 2. Solar panel with switching between separate LIpo batteries and ability to run any instrument on either battery and/or charge either battery. Switched gear warn system. Circuit breakers (not fuses), simple compass. Total Cost about $14,000 USD ROY Sounds good, except I would go with the Air Avionics ACD (Air Control Display), paired with the KRT2 and VT-01 Mode S transponder (saves 1 panel cutout). And I would add the Garmin GDL 82 ADS-B. I would also use the Air Avionics altimeter (it's awesome!). Schleicher has a thing about circuit breakers (?!). Tom The Air Avionics ACD is awesome, but has some limitations when used with the KRT2. It will also control a Becker. When you use the ACD-57 as a two or three purpose head, it saves panel cutouts, but you loose some display information as the display is shared. I'd probably do two, one for radio, another for altimeter and xponder control. I'm not certain the VT-01 Mode S is as yet legal in the US as an ADS-B vehicle. Sadly Trig will not let the ACD control their xpdnr. |
Dream Panel
Air Glide S for inertial vario and wind
Biggest LX90x0 you can fit into panel Powerflarm AIR ACD altimeter (for transponder and radio) AIR Traffic display for flarm alerts Winter 80mm ASI, not the small one |
Dream Panel
At 07:32 18 July 2018, krasw wrote:
Air Glide S for inertial vario and wind Biggest LX90x0 you can fit into panel Powerflarm AIR ACD altimeter (for transponder and radio) AIR Traffic display for flarm alerts Winter 80mm ASI, not the small one I'd look for a radio that has a double knob for setting the frequency, outer for MHz, inner for KHz. This will be a lot easier to use than the ones that involve a single knob and a button to change the digit to set. There is one of the modern small radios like this, Trig maybe. Chris |
Dream Panel
On Tuesday, July 17, 2018 at 6:02:53 PM UTC-7, 2G wrote:
As you may already know, I am ordering a new ASH31Mi. I am in the process of coming up with the panel layout and instrument selection. I would love to here from other pilots what they consider to be their dream panel (cost is not an issue). Tom Does nobody want an adsb-in receiver and traffic display? |
Dream Panel
Space is limited and Flarmview 2 does much of traffic display. Roy |
Similar Threads | ||||
Dream Panel | [email protected] | Soaring | 24 | September 24th 15 07:42 PM |
I have a dream. A GPS/SBAS/QZSS dream ! In honour of MLK day. | macpacheco | Instrument Flight Rules | 2 | January 19th 11 12:39 AM |
A Dream | franck jeamourra | Piloting | 0 | March 27th 04 07:43 PM |
A dream | franck jeamourra | Simulators | 0 | March 25th 04 12:26 PM |
a dream | franck jeamourra | Owning | 0 | March 25th 04 06:26 AM |
