Grob 102 maintenance and parts manual
Old March 8th 20, 08:23 PM posted to rec.aviation.soaring
Default Grob 102 maintenance and parts manual
I wrote couple of email's to LTB Lindner but they did not respond at all. That id not tipical German behaviour. From mine personal experience Schempp Hirth and Alexander Schleicher are much more serious snd quite responsive. Regrds Joško
Old March 9th 20, 03:17 AM posted to rec.aviation.soaring
On Sunday, March 8, 2020 at 4:23:09 PM UTC-4, wrote:
I wrote couple of email's to LTB Lindner but they did not respond at all. That id not tipical German behaviour. From mine personal experience Schempp Hirth and Alexander Schleicher are much more serious snd quite responsive.. Regrds Joško
Josko,
I asked Linder the same thing about the manual and would not sell it to me. What I found out, that they have a blue print (original drawing) that they would sell one small part at the time. I ordered bolts and locking nuts from them. The nuts were not matching the bolts. They made me send them back and I did. Linder never sent me the replacement parts. As the manual I have a very tiny part of the original drawing for those small bolts. I can only way check out on a correct assembly that I travel 2-3 hours to see an other Grob 102 and take lots of pictures. Good luck.
Old March 9th 20, 04:53 PM posted to rec.aviation.soaring
Shaun Wheeler
Lindner has not done the Grob product line any favors with me.
Old March 10th 20, 08:21 PM posted to rec.aviation.soaring
Uhhhh that's not good news. But I suspected that situation is like that. I send 2 emails to Lindner and they did not respond.
Same is with Grob aerospace .... I'ts a shame for German aviation. Compleately different situation is with
Schempp Hirth and Alexander Schleicher, they are quick and quite expeditive.
Old March 10th 20, 04:21 AM posted to rec.aviation.soaring
AS
I contacted LTB Lindner last December for some drawings to identify the parts we needed for our 102. Got them as a .pdf including the BoM. Once I knew what we needed, I emailed them again to place the order. I had the parts including the Form 1 in hand two weeks later. They were very responsive and reasonably priced - no complaints here!
Uli
'AS'
Old March 10th 20, 04:26 AM posted to rec.aviation.soaring
soaringjac
Uli
'AS'
I have had the same experience as well. They were very responsive and easy to work with.
Old March 10th 20, 08:34 PM posted to rec.aviation.soaring
Dear Uli how I can get drawings in pdf which You have?
Long time ago somewhere around 2009 my friend and I made 3000 hours inspection on my club member Astir cs 77
We removed everything and made photo documentation to be sure during assembly. In the meantime I changed two or tree PC and lost data.
But now I,m owner of an Astir Jeans.
My email is and .
Regards
Josko
Old August 2nd 18, 01:51 AM posted to rec.aviation.soaring
Casey[_2_]
forgot; SPEED ASTIR II (26), SPEED ASTIR IIB (79)
Old August 12th 18, 05:49 AM posted to rec.aviation.soaring
Sorry for the late follow up but I got overwhelmed with other stuff - I looked at our 102 Standard III maintenance manual and repair manual and the airbrake system diagram doesn't look detailed enough to be of help - it just shows the major parts in a wing cutaway. If you haven't worked things out already Lindner is probably your best bet unless someone with a good CS (or maybe a CS-77) can take some pictures for you. I can take a picture of our Standard III tomorrow but it could well be different in the details to the CS.
Old March 8th 20, 08:14 PM posted to rec.aviation.soaring
Dear colegue,
I have an Astir CS jeans but do not have any technical documentation but flight manual. If You have parts catalogue or any document where is visible aragement of part I would like to have. I know that Yours Astir is different than mine but fuselage is almost same. Picture with mobile phone and Whatsapp or viber will be very kind. My mobile is +385 98 584 714. Best regards from Split Croatia. Joško Kunac
Grob 102 Maintenance manual toad Soaring 0 April 14th 08 04:21 PM
Aircraft Maintenance & Parts Manual Trade List Update NW_Pilot General Aviation 9 July 10th 07 12:27 AM
Aircraft Maintenance & Parts Manual Trade List Update NW_Pilot Piloting 10 July 10th 07 12:27 AM
Aircraft Maintenance & Parts Manual Trade List Update NW_Pilot Owning 7 July 10th 07 12:27 AM
Grob G-102 maintenance Stephen Szikora Soaring 4 November 25th 04 09:49 AM
