Vario Comparison
Old September 9th 18, 03:58 PM posted to rec.aviation.soaring
Dan Marotta
Default Vario Comparison
Sounds like a great idea.Â* Maybe you could use a micro switch in the
landing flap position to change the mode of your AoA device.
On 9/8/2018 6:14 PM, SoaringXCellence wrote:
AOA devices are becoming very common in the experimental/homebuilt airplane world. A recent publication from the FAA (!) recommended that pilots consider getting a AOA sensor installed in their airplane. The newer completed aircraft in the famous Vans Aircraft RV series are almost all equipped with a AOA device.
I have been investigating a AOA system to install in gliders for several years but keep running into challenges due to flaps and spoilers and their effect on the system. The whole device is very easy if the airflow and overall AOA doesn't change much with configuration changes.
One fix is to set the system primarily for landing and disable it for other flight regimes. Unfortunately that means you can't use the best L/D AOA, or other selected angles to correct for weight changes.
I also have a Raspberry Pi and considered just starting to log the data for my glider. This winter I'm doing a refinish; maybe that a good time to install the pressure sensors and start logging.
Mike
Dan, 5J
Old September 9th 18, 04:26 PM posted to rec.aviation.soaring
Dave Walsh
Pretty sure all recent DGs come with stall warning built in.
DG's web site explains the background to their thinking.
The system in the DG808C I used to own was pretty good; you
got a verbal warning, hard to misinterpret "Stall, stall".
Dave Walsh
Aircraft comparison Jkgoblue Owning 1 November 23rd 05 10:18 PM
Vario Comparison Update Paul Remde Soaring 4 January 9th 05 08:51 PM
F-22 Comparison robert arndt Military Aviation 39 December 4th 03 04:25 PM
Comparison of IFR simulators Chris Kurz Simulators 0 October 27th 03 10:35 AM
EMW A6 Comparison to X-15 robert arndt Military Aviation 8 October 2nd 03 02:26 AM
