Glider Cockpit Safety
Old September 9th 18, 05:26 PM posted to rec.aviation.soaring
Ramy[_2_]
Default Glider Cockpit Safety
Ballistic chutes would save more lives then safety cockpit. Too bad that ballistic chutes are not built into every glider. There would be far less fatalities.
Ramy
Old September 10th 18, 06:56 AM posted to rec.aviation.soaring
krasw
Ramy
Yes, safety cockpit can save you or your back in occasional landing gone bad, probably survivable anyway. Spinning to ground or crashing ridge at flying speed is not survivable with any cockpit, there is too much energy and too little structure to absorb this.
European ultralights (LSA with 1000lb MTOW) are mostly (?) equipped with airframe rocket parachutes. Cost doesn't seem to be prohibitive, judging from number of them in use. This should have been mandatory equipment for gliders since 90's, think of lives saved after midairs.
Old September 10th 18, 07:42 AM posted to rec.aviation.soaring
Chris Rowland[_2_]
that
f=
atalities.=20
=20
Ramy
ba=
flyi=
t=
ai=
from=
glide=
Ballistic chutes can only protect against problems at altitude, high enough
for the chute to deploy. If the accident only starts to happen at low
altitudes then it won't help at all. And the chute has to be menually
deployed so the piilot has to recognise there is going to be an accident
while still at altitude. Not sure how many glider accidents meet these
criteria. Midairs are the only ones I think.
Chris
Old September 10th 18, 11:08 AM posted to rec.aviation.soaring
waremark
Is there any aircraft which has room for a ballistic shute and an engine aft of the cockpit? I think it is the popularity of engines which has prevented more widespread fitment of ballistic chutes.
Old September 10th 18, 02:45 PM posted to rec.aviation.soaring
Chris,
Ballistic chutes have been successfully deployed as low as 300 feet and BRS claims 386 lives saved, so far! Deployment requires 35 pound pull on the "little red handle", which fires the rocket hooked to a long sleeve with the parachute inside. Rocket and sleeve completely separate, leaving chute with a slider ring up near the fabric. Chute only partially fills at first, then the slider drops and allowes full deployment..........thus preventing chute failure from high speed deployment. My BRS 1050 system is good for 1050 G/W and 130mph at deployment.
JJ
Old September 10th 18, 03:25 AM posted to rec.aviation.soaring
Dan Marotta
Everything Mark said, however the F1 crashing into the wall most often
hits it with a glancing blow allowing parts to shed whereas the glider
quite often hits the ground head on.Â* I wonder how survivable an F1
crash directly into the wall at 200 mph would be...
On 9/9/2018 10:04 AM, wrote:
I've watched a lot of Formula 1 lately, where 200mph+ crashes are a regular occurrence. More often than not, the drivers walk away without a scratch.
What is to prevent glider cockpits from implementing similar safety designs?
The primary factor that imparts superior crashworthiness to F1 and Indy cars is the suspension and wings that are sheared away during impact. As components are peeled off, energy is expended and deceleration happens over a longer period of time. By the time the "tub" surrounding the driver's cockpit is next in line for a pounding, the deceleration that has already taken place reduces the energy imparted to the remaining structure. Additionally, the design of the cockpit has multiple layers of extremely strong carbon fiber and Kevlar formed in such a way that forces are redistributed around the structure and withstand penetration and crushing. The many and regular crashes occurring over the years have provided a wealth of data for the design of each succeeding generation of racing cars. Very little data is collected for the teeny-tiny sailplane market, with only three or four manufactures worldwide.
Modern sailplanes comply with CS-22 crashworthiness standards that spell out minimum requirements for structural rigidity and cockpit penetration. Unfortunately, bringing crashworthiness up to F1 standards would require a cockpit that would be lots heavier and might not help much at all, as the deceleration of the little pink body inside is difficult to control. You can scramble an egg inside the shell.
Perhaps the next generation of composites (graphene, etc.) will allow for more robust structural integrity, but be prepared for a large price increase.
Dan, 5J
Old September 10th 18, 03:36 AM posted to rec.aviation.soaring
Kevin Christner
Appears to be pretty survivable:
https://www.youtube.com/watch?v=loNgEDxeQc8
Dan, 5J
Old September 10th 18, 04:18 AM posted to rec.aviation.soaring
Charlie Quebec
My DG 202 has a double wall safety cockpit, there is no removable seat pan for this reason.
Old September 11th 18, 12:49 AM posted to rec.aviation.soaring
2G
Dan, 5J
Not good:
https://www.youtube.com/watch?v=VDjKCoHD278
Tom
Old September 11th 18, 01:15 AM posted to rec.aviation.soaring
Well, basically head first in an open cockpit is not a good judge of cockpit safety. Sorta like landing glider canopy first (upside down), the cockpit never really comes into play.
Glider Safety Webinar Tom[_12_] Soaring 3 January 3rd 12 10:53 PM
Glider Safety Tom[_9_] Soaring 1 March 2nd 10 03:41 PM
Glider Safety Tom[_9_] Soaring 65 March 1st 10 11:39 PM
Glider Safety, etc. None[_2_] Soaring 3 February 27th 10 03:46 PM
SAFETY TOOLS IN OUR COCKPIT [email protected] Soaring 7 October 17th 08 06:04 PM
