On Friday, September 14, 2018 at 9:41:55 AM UTC-7, Paul Remde wrote:
Hi Dan, Is there any chance that you're SeeYou license has expired and you installed a version that you don't have a license for? That is somewhat common. If you have a working version and never upgrade, you can keep using SeeYou forever. But it sometimes prompts you to install an upgrade at startup. If you have a current subscription, the upgrade works great. If you haven't purchased SeeYou or SeeYou-Upgrade in the last year, some features will be disabled if you are using a version that was released after your subscription ended. What does SeeYou display in the title-bar? Is should be something like, "SeeYou 9.2 - Dan". If it says something about it being a demo version, the go to the menu bar and select Help, Registration and log into the SeeYou Cloud. You will see there whether or not you have a current subscription. If you need to buy SeeYou-Upgrade, I'd be glad to help you with that. It is $59. Best Regards, Paul Remde Cumulus Soaring, Inc. ________________________________________________ On Wednesday, September 12, 2018 at 2:56:57 PM UTC-5, Dan wrote: recently my 3-D map view feature stopped working on SeeYou 9.2. It had been working great but now is hung up and all I see is a brown screen. I've contacted the SeeYou help desk, they suggested to update my graphics card drivers, did that and still nothing. I'm waiting for further instructions from Naviter but I was wondering if anyone here can help. Thanks in advance, Dan 7DR Paul, my license is good until February 2019 thanks Dan |
On Wednesday, September 12, 2018 at 3:56:57 PM UTC-4, Dan wrote:
recently my 3-D map view feature stopped working on SeeYou 9.2. It had been working great but now is hung up and all I see is a brown screen. I've contacted the SeeYou help desk, they suggested to update my graphics card drivers, did that and still nothing. I'm waiting for further instructions from Naviter but I was wondering if anyone here can help. Thanks in advance, Dan 7DR I had the same problem pop up and I was able to fix it by doing this: Load an IGC file into SeeYou 1) Go to Tools Options then go to "3D View" under the FLIGHT option 2) Then look toward the bottom of the dialog box under "Camera". The "Distance" option had some incredibly large number such as "1231256531mi" and I changed it to "0.5mi" 3) Under "Height", I changed the incredibly large number to "3000ft" Magically my 3D render appeared again. I'm not sure if this will correct your situation, but it resolved mine. I have no idea why those large values were populated in those two fields ... perhaps filled in automatically after the software was upgraded to v9.2?? Roger |
On Saturday, September 15, 2018 at 5:02:58 PM UTC-7, wrote:
On Wednesday, September 12, 2018 at 3:56:57 PM UTC-4, Dan wrote: recently my 3-D map view feature stopped working on SeeYou 9.2. It had been working great but now is hung up and all I see is a brown screen. I've contacted the SeeYou help desk, they suggested to update my graphics card drivers, did that and still nothing. I'm waiting for further instructions from Naviter but I was wondering if anyone here can help. Thanks in advance, Dan 7DR I had the same problem pop up and I was able to fix it by doing this: Load an IGC file into SeeYou 1) Go to Tools Options then go to "3D View" under the FLIGHT option 2) Then look toward the bottom of the dialog box under "Camera". The "Distance" option had some incredibly large number such as "1231256531mi" and I changed it to "0.5mi" 3) Under "Height", I changed the incredibly large number to "3000ft" Magically my 3D render appeared again. I'm not sure if this will correct your situation, but it resolved mine. I have no idea why those large values were populated in those two fields ... perhaps filled in automatically after the software was upgraded to v9.2?? Roger Roger, You Nailed it! Worked just as you described and now mine is working great. Many many thanks, Dan |
On Saturday, September 15, 2018 at 9:05:50 PM UTC-7, Dan wrote:
On Saturday, September 15, 2018 at 5:02:58 PM UTC-7, wrote: On Wednesday, September 12, 2018 at 3:56:57 PM UTC-4, Dan wrote: recently my 3-D map view feature stopped working on SeeYou 9.2. It had been working great but now is hung up and all I see is a brown screen. I've contacted the SeeYou help desk, they suggested to update my graphics card drivers, did that and still nothing. I'm waiting for further instructions from Naviter but I was wondering if anyone here can help. Thanks in advance, Dan 7DR I had the same problem pop up and I was able to fix it by doing this: Load an IGC file into SeeYou 1) Go to Tools Options then go to "3D View" under the FLIGHT option 2) Then look toward the bottom of the dialog box under "Camera". The "Distance" option had some incredibly large number such as "1231256531mi" and I changed it to "0.5mi" 3) Under "Height", I changed the incredibly large number to "3000ft" Magically my 3D render appeared again. I'm not sure if this will correct your situation, but it resolved mine. I have no idea why those large values were populated in those two fields ... perhaps filled in automatically after the software was upgraded to v9.2?? Roger Roger, You Nailed it! Worked just as you described and now mine is working great. Many many thanks, Dan Now you need to buy Dan *and* Mike some beers. |
On Saturday, September 15, 2018 at 10:15:48 PM UTC-7, Darryl Ramm wrote:
On Saturday, September 15, 2018 at 9:05:50 PM UTC-7, Dan wrote: On Saturday, September 15, 2018 at 5:02:58 PM UTC-7, wrote: On Wednesday, September 12, 2018 at 3:56:57 PM UTC-4, Dan wrote: recently my 3-D map view feature stopped working on SeeYou 9.2. It had been working great but now is hung up and all I see is a brown screen. I've contacted the SeeYou help desk, they suggested to update my graphics card drivers, did that and still nothing. I'm waiting for further instructions from Naviter but I was wondering if anyone here can help. Thanks in advance, Dan 7DR I had the same problem pop up and I was able to fix it by doing this: Load an IGC file into SeeYou 1) Go to Tools Options then go to "3D View" under the FLIGHT option 2) Then look toward the bottom of the dialog box under "Camera". The "Distance" option had some incredibly large number such as "1231256531mi" and I changed it to "0.5mi" 3) Under "Height", I changed the incredibly large number to "3000ft" Magically my 3D render appeared again. I'm not sure if this will correct your situation, but it resolved mine. I have no idea why those large values were populated in those two fields ... perhaps filled in automatically after the software was upgraded to v9.2?? Roger Roger, You Nailed it! Worked just as you described and now mine is working great. Many many thanks, Dan Now you need to buy Dan *and* Mike some beers. Beers for Roger! Kick in the Jimmy for SeeYou software writers....bug, no it is a feature! Dan |
OLC issues | Ramy | Soaring | 4 | June 10th 09 07:55 AM |
OLC issues | Ramy | Soaring | 9 | March 5th 09 04:58 AM |
SeeYou Mobile and CAI 302 Issues Resolved? | Frank | Soaring | 1 | December 28th 06 11:09 PM |
Seeyou NMEA to Winpilot/Seeyou | Jean | Soaring | 4 | June 3rd 06 11:38 AM |
Issues around de-ice on a 182 | Andrew Gideon | Owning | 35 | July 18th 04 06:42 PM |
