What electronics are worth buying
Old October 28th 18, 01:53 AM posted to rec.aviation.soaring
Tango Eight
Default What electronics are worth buying - PLBs
meant to add...
In all circumstances that involve "parking" somewhere other than the home 'drome, communication is what you need. Most places have cell coverage, problem usually solved. Enough gaps exist that there is motivation for adding additional toys. The PLB doesn't add much. One button to call the cavalry. It's an incredibly limited tool.
A typical US glider pilot using 100 hrs of ten minute tracking and 6 months of service can have text messaging (and tracking and 911) from anywhere for about $150 annually with inReach.
If you do need to call the cavalry, the ability to communicate your immediate situation and needs will be of prime importance.
T8
Old November 16th 18, 06:13 PM posted to rec.aviation.soaring
On Saturday, October 27, 2018 at 4:33:10 PM UTC-4, wrote:
Here is one source for the needed battery cells (with tabs pre-welded):
https://www.batterybob.com/products/...tabs-lith-8-1/
Here is a source for the whole battery pack ready to plug in, $50 - not blessed by the factory:
https://www.ebay.com/itm/ACR-ResQlin...1/332810112016
The price for non-factory-authorized battery is now down to $39:
Or, for $55 they will also do the battery-replacement labor for you, includes shipping back to you:
https://www.ebay.com/itm/ACR-Resqlin...5/332852007531
Note: I am not affiliated with this seller, and have not used their service. If anybody does deal with them, let us know how it went.
Old October 28th 18, 01:01 AM posted to rec.aviation.soaring
Dan Marotta
You can order a replacement battery pack he
http://battery.com.sg/our-products/4...7238-LI&brand=
Or you can easily build your own using CR123 lithium batteries with
solder tabs:
There are probably other solutions, but I like the do it yourself option.
On 10/27/2018 2:23 PM, wrote:
On Saturday, October 27, 2018 at 2:41:06 PM UTC-4, John Huthmaker wrote:
There is some weird speculation on this battery deal. So far it doesnt seem like anyone has actually opened the case to look. Sure it could be welded in. Or it could have some little clip that takes a handful of seconds to unplug. If its 50% the cost of the device to replace the battery, I would risk it and crack the device open. Because if I broke the device, I would chock it up to replacing legacy technology with something brand new. Maybe I'm just less risk averse because I've been building computers for 30 years, and have never shied away from cracking the case on something.
Certainly some people have opened it up. For example (with pictures):
https://advrider.com/f/threads/acr-r...cement.749245/
I'm confident I can replace the batteries myself, even if it requires soldering. And apparently you don't even need to "crack" the case, only unscrew a few screws. The issue is, if you buy generic batteries whereever, how can you be sure that they are of high enough quality to rely on them powering the PLB for 24 hours 5 years later?
Regarding the re-sealing of the case promised as part of the official battery replacement (how much can a gasket cost?), that is important if you are using the PLB for water sports. For aviation, not so much. Yes you may have a "water landing", but that's rather unlikely.
Dan, 5J
Scanning vrs electronics Waveguru Soaring 7 March 20th 16 05:09 PM
Single Pilot IFR training dvd, worth buying? steve[_1_] Piloting 4 November 13th 07 06:10 AM
For the electronics experts here mark Home Built 5 July 5th 06 02:26 AM
Are these USS Kitty Hawk uniforms worth buying off eBay? UUMe Naval Aviation 24 December 2nd 03 04:35 PM
