IGC-approval for the LX 10000 Flight Recorder
Old November 11th 18, 11:53 AM posted to rec.aviation.soaring
Ian Strachan
Default IGC-approval for the LX 10000 Flight Recorder
I am pleased to announce IGC-approval for the LX 10000 Flight Recorder, manufactured by LX Navigation d.o.o. of Celje, Slovenia. The level of approval is for "all flights".
The IGC-approval document may be downloaded from either the GFAC or FAI/IGC web sites, see below, together with other information on IGC-approved Flight Recorders.
Ian Strachan
Chairman, IGC GNSS Flight Recorder Approval Committee (GFAC)
www.ukiws.demon.co.uk/GFAC
There are now 62 main types of IGC-approved Flight Recorders from 20 different manufacturers. When different models within types are added, the total rises to 70.
If you own or fly with one of these recorders, it is recommended that you download its latest IGC-approval document from one of the web sites given below, and note any changes that may affect how you operate it.
A table of all IGC-approved FRs with links to Approval Documents is the first item on the web site before the set of Approval documents for each type of recorder. This includes the following:
(1) a table of all types of IGC-approved Flight Recorders in alphabetical order of manufacturer name, with links to their IGC-approval documents in the right hand column under "Date of Latest Document".
(2) a table of Manufacturers of IGC-approved Flight Recorders, in alphabetical order of name.
(3) a diary of all IGC-approval activity from the first IGC-approvals in 1996 to the present day, most recent events first.
(4) a history of GNSS Flight Recording in IGC together with pictures of some early Recorders.
For the GFAC web site, see: www.ukiws.demon.co.uk/GFAC - the complete table can be viewed directly at:
www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf
Navigating the IGC web site:
go to: www.fai.org/igc-documents
Scroll down and click "Flight Recorders",
look down and click on: "IGC-approved Flight Recorders - Approval Documents"
then click on "IGC-approval Documents for all IGC-approved Flight Recorders"
This will call up a list of documents, the first one being:
"Table - all IGC-approved FRs - links to Approval documents - Manufacturer table - List of updates - History of FRs in IGC"
This table lists the name and main characteristics of individual IGC-approvals and in the last column of this table there is a link to individual documents, click the link to display the document
The table is followed by a list of individual IGC-approval documents in alphabetical order of manufacturer’s name from Aircotec to Zander. These can be called up by clicking the document name.
IGC-approval - GENERAL
IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code for gliding and the Technical Specification for IGC-approved GNSS Flight Recorders.
The Technical Specification is available through the igc-documents web site above
or
directly from the GFAC web site:
http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf
Programs that have been notified to IGC for the analysis of IGC files are listed on the GFAC web site under: "Analysis Programs for IGC Flight DataFiles"
The IGC Shell program for Validation of the structure of IGC files may be downloaded he
www.ukiws.demon.co.uk/GFAC/downloads.htm
This downloads the file IGCDLL.zip, which when un-zipped, gives the free IGC Shell program. This web site also contains the latest FR Manufacturers’ Data Link Library (DLL) files that are used by IGC Shell and other programs to Validate the structure of an IGC file. The IGC file Validate check ensures that the IGC file came from a serviceable and secure FR, and the file is identical to when it was originally downloaded. This check is required before a flight performance recorded in the IGC file can be approved to the standards of IGC.
Finally, the Sporting Code for gliding (SC3) and its annexes A-D may be downloaded via: www.fai.org/igc-documents in which "Sporting Code - Section 3: Gliding" is at the top of the list
Old November 12th 18, 06:14 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I have received some feedback suggesting that I clarify what an LX 10000 is..
According to the IGC Approval Document, the LX 10000 is, "an Era 80 with the controls under the screen rather than at the side, and no variometer function in its display" It is a product of LX Navigation.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_____________________________________________
Ian Strachan
or
IGC approval - LXNAV Nano 4 Flight Recorder [email protected] Soaring 4 February 21st 17 05:37 PM
IGC approval for the LX9000HAFR Flight Recorder Ian Strachan Soaring 0 August 3rd 16 10:29 PM
IGC-approval - Naviter Oudie-IGC GPS Flight Recorder Ian Strachan Soaring 5 March 4th 16 02:34 PM
IGC-approval for the FlarmMouse Flight Recorder Ian Strachan Soaring 0 August 2nd 13 12:37 PM
New IGC-approval for GNSS Flight Recorder Ian Strachan Soaring 0 February 14th 09 08:00 PM
