Why determine the handicaps dry? Surely in competition, most gliders are being flown pretty much maxed out with ballast. It would make more sense to use the MTOW as the reference weight and then it would take out these discussions about FES being heavier than standard.
On Friday, March 1, 2019 at 1:42:52 PM UTC-5, wrote:
Why determine the handicaps dry? Surely in competition, most gliders are being flown pretty much maxed out with ballast. It would make more sense to use the MTOW as the reference weight and then it would take out these discussions about FES being heavier than standard. The list is specifically designed for Sports Class, thus the title. By definition those ships are flown without disposable ballast. UH |
On Wednesday, February 27, 2019 at 9:07:37 PM UTC-6, Tony wrote:
Yes. https://www.ssa.org/ContestHandicaps When you click the download "here" button the files is unreadable. The web page content says it is from 2009. |
On Thursday, February 28, 2019 at 7:02:55 AM UTC-7, Tom (TK) wrote:
On Wednesday, February 27, 2019 at 9:07:37 PM UTC-6, Tony wrote: Yes. https://www.ssa.org/ContestHandicaps When you click the download "here" button the files is unreadable. The web page content says it is from 2009. According to the page/link that I open it is the current list. It appears that there is a penalty for the A model although it is claimed to have noticeably higher performance in glide. Handicapping must be one of the "Dark Arts". |
I assume the handicaps are weight based and do not include any adjustments for prop drag on FES models or drag from unsealed bay doors for gliders with motors on a mast.
Is that correct? I don't know of any data on unsealed bay doors. I do believe data on FES drag is out there someplace. Thanks! Lou |
On Thursday, February 28, 2019 at 10:58:59 AM UTC-5, MNLou wrote:
I assume the handicaps are weight based and do not include any adjustments for prop drag on FES models or drag from unsealed bay doors for gliders with motors on a mast. Is that correct? I don't know of any data on unsealed bay doors. I do believe data on FES drag is out there someplace. Thanks! Lou "Results of Flight Performance Determination of the Lak‐17a FES (S5‐3117) using the comparison flight method in Aalen‐Heidenheim‐Elchingen, August 20th and 21st 2012" - you can see it at http://www.front-electric-sustainer....A%20FES_en.pdf . If the link doesn't work use your search engine with title to find it. Fig 9 shows what to my eye is about 2 pts less of L/D at 160 kph and they say: "A clearly determinable but small drag increase due to the presence of the two propeller blades can be seen." If you look at the most current (2018) DAeC (German) handicaps ( https://www.daec.de/fileadmin/user_u...-WO_2018ki.pdf "), the handicap for FES is the same as the base glider, which seems to indicate that the increase in wing loading and the drag of the FES balance, which seems reasonable. Dan |
I assume the handicaps are weight based and do not include any adjustments for prop drag on FES models or drag from unsealed bay doors for gliders with motors on a mast. Is that correct? I don't know of any data on unsealed bay doors. I do believe data on FES drag is out there someplace. Thanks! Lou There is a 1.4% adjustment for props on FES ships, developed from information available last year when this first came up. UH |
US: Pilot Ranking List (PRL) for 2019 | John Leibacher | Soaring | 1 | October 22nd 18 07:38 PM |
Nephi OLC 2019 | Nick Kennedy[_3_] | Soaring | 0 | October 7th 18 12:10 AM |
2019 US Nationals | [email protected] | Soaring | 6 | August 28th 18 10:36 PM |
How is handicap weight determined for the SSA handicap list? | AK | Soaring | 1 | September 25th 07 01:43 PM |
SSA HANDICAP LIST | [email protected] | Soaring | 11 | September 17th 04 02:58 AM |
