Undershoot Vs. Overshoot airport landing accidents
Old April 18th 19, 09:05 PM posted to rec.aviation.soaring
Tango Whisky
Default Undershoot Vs. Overshoot airport landing accidents
Yes. Anytime.
Old April 18th 19, 11:14 PM posted to rec.aviation.soaring
Paul Agnew
Lots of great insight to digest...Dive and Drag is an interesting solution, if you have enough runway to scrub off the excess speed and/or your spoilers are effective. My ASW19 stock spoilers are just not effective enough for me to try the Dive and Drag method.
Reverse Base Method = 180° turn to reverse + 90° turn to final = 270° (two turns & wind corrections).
Why not just make a stable, descending 270° turn when crossing the final? In powered, fixed-wing aircraft, it's not unusual to get assigned a right or left 270 to final by tower to improve spacing on departing aircraft. It's a basic ground reference maneuver that could be adapted for gliders so you roll out aligned with the runway.
We're supposed to be able to turn back to land above 200ft with a rope break, which is based on our collective understanding that we can safely execute a turn, maintain speed, and align with the runway from that minimum altitude. That requires 180° of turn, if the towplane drifted downwind and you turn into the wind (ideal, but our guys don't). Or, 210-270° total if you have to reverse course, angle for the runway, then turn back to align with the runway. The second scenario requires multiple, low-altitude turns. Is that ideal?
Performing a stable, 270° or 360° turn for altitude correction should be within out skillset, but only if the excessive altitude is above a certain threshold for your ship. 100-200ft high? Maybe not the best option. Clear knowledge of your ship's descent rate in a turn is critical for decision making.
That said, I've always been successful with a little slip to correct for any excess altitude. Starting the correction on the base leg and performing a slipping turn to final burns off a lot of excess altitude. (I learned to do this with Phil Beale on my CFI-A checkride back in 1986.)
Paul A.
Jupiter, FL
Old April 18th 19, 11:26 PM posted to rec.aviation.soaring
Jonathon May
solution,=
and/or your
spoile=
enough
for=
me to try the Dive and Drag method.=20
Reverse Base Method =3D 180=C2=B0 turn to reverse +
90=C2=B0 turn to final
=3D 270=C2=B0 (two turns & wind corrections).
Why not just make a stable, descending 270=C2=B0 turn when
crossing the
fin=
assigned a
ri=
aircraft.=
for gliders
s=
a rope
brea=
safely
execut=
minimum
altit=
ude. That requires 180=C2=B0 of turn, if the towplane drifted
downwind and
270=C2=B0
total=
back to
ali=
altitude
tur=
ns. Is that ideal?=20
Performing a stable, 270=C2=B0 or 360=C2=B0 turn for
altitude correction
sh=
above a
best
option.=
for
deci=
sion making. =20
for
an=
performing
a=
learned to
d=
o this with Phil Beale on my CFI-A checkride back in 1986.)=20
Paul A.
Jupiter, FL
When we flew K7 and K13 you could dive against the brakes,
provided you open the air brakes about 50kn then lowered the
nose the speed gain was not too high.If you put on 70Kn then
opened the airbrakes the speed would not reduce much.
However if you try that in a Mk 1 Duo discus you will be zooming
down the runway at 120+kn waiting for the boundary fence.
Old April 19th 19, 01:16 AM posted to rec.aviation.soaring
Dave Nadler
On Thursday, April 18, 2019 at 5:14:05 PM UTC-4, Paul Agnew wrote:
...My ASW19 stock spoilers are just not effective enough...
Yup, do the -19 spoiler upgrade that adds an additional panel,
nice to have that additional drag and safety margin!
Old April 19th 19, 05:08 AM posted to rec.aviation.soaring
Paul Agnew
It's on the wish list along with the lift up binacle and disc brake mod. There's nobody in our area that is familiar with gliders enough to engage them for the spoiler mod.
PA
Old April 23rd 19, 12:45 AM posted to rec.aviation.soaring
On Thursday, April 18, 2019 at 2:05:10 PM UTC-5, Tango Whisky wrote:
Yes. Anytime.
This isn't intended to come across as a "I told you so", but educational for those who predicted that a steep full spoiler approach will put you into the far fence at high speed.
Arcus M, 1650 lbs. starting out close to the same spot as the first video and also 1,200 ft MSL (field elevation 300) and I had to close spoilers almost fully to clear the 20' high power lines on the approach end of the "extension" at SCOH. I adjusted pitch just a tad and ballooned before touchdown but total distance over the 20' wires was approximately 1,400 ft and without significant braking my landing roll was on the order of 700-800ft per Google Earth.
I will try this again, but starting much higher and post again. With full spoilers and modest increase in airspeed you can scrub a lot of altitude. Recommended to be tested at altitude first.
Video at the following link:
https://youtu.be/2-KiGtSbkMA
Mark
Old April 23rd 19, 06:43 AM posted to rec.aviation.soaring
Tango Whisky
The Arcus is a completely different ship and has decent airbrakes. The Duodiscus hasn't.
Old April 23rd 19, 01:25 PM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
Well ? If one has wings level with spoilers deployed and is anticipated running out of runway why not throw left and right rudder to skid ?
Old April 23rd 19, 09:01 AM posted to rec.aviation.soaring
Jonathon May
airbrakes. The
Duodiscus hasn't.
The Duo discus didn't but
The Duo Discus XL has excellent brakes and has been around 10
years now.
The Arcus is more like the XL
Preventing Landing Accidents Glider Safety Webinar Tom[_12_] Soaring 0 January 18th 12 07:49 PM
Overshoot in Honduras? Mike Isaksen Piloting 12 June 2nd 08 02:53 PM
Hawk overshoot [1/1] Peter Twydell Aviation Photos 0 March 25th 08 08:20 PM
Preventing Landing Accidents DVD [email protected] Soaring 0 March 26th 07 05:56 PM
Preventing Landing Accidents Video Thomas Knauff Soaring 0 March 21st 04 03:01 PM
